Need help with nocords.xyz Pluto
nocords.xyz - the M3U file there is full of channels giving me 403s. I'm in the US, not using a VPN or trying to do anything hinky. Has Pluto locked IPTV down, or ???
Everything is operating normally at nocords.xyz
I could really use some help from someone to try to figure out why I'm getting 403s. I've tried over a couple of VPNs with the same result. I have absolutely no idea how to proceed, and would really appreciate any pointers.
I can play from the Pluto app just fine, so it isn't like they've decided to block Cox or something.
I could really use some help to try to figure this out. There has to be a way to collect information that will tell what's going on, but I have no idea where to start.
Have you tried rebooting your router? You're posting all over the place about different sources for Pluto and it sounds like your issues are local, based upon what little info you've given.
What does your Channels DVR Custom M3U Source settings look like?
This Community Forum is for Channels DVR and clients.
