Need help with removing server from cabin?
We have our primary home in PA ans I use my server from there to watch TV using CDVR.
I setup a raspberry pi at our family cabin in NC to stream my mom's YTV when she is there.
Originally I setup the family cabin under my account (2nd DVR). But in doing so, I can't switch to my main home server when accessing from TVs at the cabin. I logout of the client, reconnect using Away from home, but it still maps back to the local server at the cabin.
I've tried turning off the local server, setting it up under a seperate account, but each time I logout of the client and try and connect via Away from Home, it continues to point back to the cabin server (even though it's now under a different account). I turned off bon jour in the server settings, but that does nothing.
Any suggestions on how to address?
Tia,
Jay
Couple of things to try, first disable remote and Bonjour on the pi
Option 1. If you are not using the beta on the client, download it and attach away from home
Option 2. Delete the client app then reinstall app, attach away from home
Thanks Rice, the Beta was a great suggestion. Now I can have both setups on the same TV.
