NESN Plus?
With our overlapping sports seasons this year, NESN is putting its alternate NESN+ feed to use (available in the NESNGo standalone app).
Any chance of adding this to Channels?
Are you able to stream it through a web browser using your TV service credentials? If so please post the URL here so the Devs can check it.
Yes, it can be streamed via a desktop browser (NESN and NESN Plus are tabs within the same frame.)
What URL are you looking for? Right clicking reveals nothing -- debug console reveals something like:
https://nesngo7.akamaized.net/hls/live/712399/nesnplus0811140738 ......
(edit)
Address bar shows the following when the NESN Plus tab is selected:
"h t t p s://nesngo.nesn.com/nesn-plus" (spaces inserted to avoid resolving addy)
Try the pre-release. Click-and-hold on the Check for Update button. Click pencil icon under your source, click EDIT at the top right, scroll down and click Rescan next to the new channel.
Just updated. It seems that while NESN+ has been added at 6172, both NESN and NESN+ are now reporting "playmaker error: INVALID_RESOURCE_ID"!
I just updated again, from 2020.08.11.2355 to 2020.08.12.0241. NESN is now working again, but NESN+ is still returning 'playmaker error: INVALID_RESOURCE_ID' on a rescan.
(edit) Don't know if it's related, but the audio on NESN is now out of sync (by about 5 seconds). It's not out of sync on the NESN Go website or the mobile apps.
(another edit) Now, NESN+ is working, but NESN is throwing the above error :frowning:
It looks to me like only one, NESN or NESN+, could be authenticated at a any given time but not both at the same time. If one is authenticated, the other one cannot and vice-versa.
The issue with only one channel working at a time is fixed in v2020.12.31.0029
