New Customer Remote Streaming Problem
Channels is incredible! So fast! Loving the commercial skip. However, I'm having difficulty getting remote streaming to work.
My setup: T-mobile 5G home internet gateway. Orbi RBK50 router connected to T-mobile gateway via CAT6. HDHomeRun Flex 4k connected to Orbi router via CAT6. Server is M1 MacMini running OS 12.0.1.
I have tried automatic mode. Didn't work. I then tried manual mode setting port forwarding up for internal and external port 8089 for my server's IP address on the Orbi router. Didn't work.
I then ran the troubleshoot diagnostics and got the following error message:
could not connect to 02a683e7fd88.u.channelsdvr.net. Check if the port is mapped.
Any ideas what is wrong?
T-Mobile does not allow remote connections.
You can try Tailscale instead
Thank you. I have tailscale now installed on the server, my iPhone, and iPad the two devices I would use channels remotely. Is that all I need to do or do I need to reconfigure port forwarding in the orbi router and channels settings?
since this is my use case, and it does work well!
However, by telling my clients to connect at 'home', I do not have the ability to download. or more selectively set the stream rate.
could that be looked into?
You can adjust the home streaming quality inside the app
I guess I was hoping to set the streaming quality by show or category, but also download to phone would really help. I assume that is an option when remote streaming works.
You've replied to a three year old thread with very little detail. What is wrong with remote access?
Downloads should work at home or remotely. Usually people download at home where it's faster.
ok, my bad. I thought it was a home/remote issue, apparently it's a ios/all others issue.
I have no apple products, not sure why we can't download on other o/s.
