New issue: No devices found
My DVR just updated to 2017.02.11.0312 and it did not find any of my devices upon startup. I manually scanned for them and they were not able to be found that way either. So, tried adding by IP address and that was successful. Note, I do not notice any loss of settings as a result meaning that all previous configured channels, and passes are still intact. It only appears that I lost the devices.
Logs don’t really provide any indication as to what went wrong:
2017/02/11 15:02:48 [SYS] Downloading new version v2017.02.11.0312
2017/02/11 15:02:51 [SYS] Update downloaded and verified successfully.
2017/02/11 15:02:51 [SYS] Shutting down for upgrade from v2017.02.10.0714 to v2017.02.11.0312
2017/02/11 15:02:51 [DVR] Recording engine stopped.
2017/02/11 15:02:53 [SYS] Starting Channels DVR v2017.02.11.0312 (darwin-x86_64) in /Users/admin/channels-dvr/data
2017/02/11 15:02:54 [HDR] Found 0 devices
2017/02/11 15:02:54 [SYS] Started HTTP Server
2017/02/11 15:02:54 [DVR] Recording engine started in /Volumes/Channels-DVR
2017/02/11 15:02:54 [SYS] Bonjour service running for dvr-lionsden.local. [192.168.1.100]
2017/02/11 15:02:54 [SYS] Removing old update 2017.02.07.0145
2017/02/11 15:02:54 [DVR] Waiting 4h57m5.273798124s until next job 1486861200-68
2017/02/11 15:02:54 [SYS] Created database snapshot: backup-20170211.150254
2017/02/11 15:02:55 [SYS] Removing old backup backup-20170201.231125
Weird. Seems like it’s connected to the internet ok…
Do other apps on the computer find the tuners? Did the computer switch wifi networks or something?
I didn’t try apps but I did try ping the tuners from the server and they pinged fine. All devices of the DVR setup are hard wired so no wifi in play.
Do they show up at http://my.hdhomerun.com?
Yes, they do show there. I’ve manually restarted the DVR several times now and the problem has not recurred. Can’t explain why it happened on the initial restart after the upgrade…
