This is not going to work sorry I need a full log I cannot even see the full file name and it looks like you are using the JSON file as input. You can use onedrive and get a share link to the log file or google drive.
Ok I will do that. Thank you!!
have to type logs in chunks
INFORMATION> --> Starting conversion - DEBUG MESSAGES
INFORMATION> --> License -> Premium
INFORMATION> --> Windows OS Version -> Microsoft Windows NT 10.0.19041.0 (WIN_10_2016_SERVER, Professional)
INFORMATION> --> Windows Platform -> 64 Bit
INFORMATION> --> MCEBuddy Build Platform -> 64 Bit
INFORMATION> --> MCEBuddy Build Version : 2.5.5.1
INFORMATION> --> MCEBuddy Build Date : 12/11/2020 10:26:04
INFORMATION> --> MCEBuddy Running as Service : True
INFORMATION> --> Manual Add Domain Name ->
Manual Add User Name -> Guest
Manual Add Password ->
Archive Path Domain Name ->
Archive Path User Name -> Guest
Archive Path Password ->
Failed Path Domain Name ->
Failed Path User Name -> Guest
Failed Path Password ->
Wake Hour -> -1
Wake Minute -> -1
Start Hour -> -1
Start Minute -> -1
Stop Hour -> -1
Stop Minute -> -1
Days of Week -> Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday
Max Concurrent Jobs -> 1
Enable Job Logs -> True
Log Level -> 3
Log Keep Days -> 15
Use Recycle Bin -> False
Delete Manually/CLI added Original -> False
Archive Manually/CLI added Original -> False
Sync Converted -> False
Allow Sleep During Conversions -> True
Pause Conversion on Battery Power -> False
Send eMails -> False
eMail settings -> Send eMail Settings -> SMTP Server ->
Port -> 25
SSL -> False
User Name ->
Password ->
From ->
To ->
Bcc ->
eMail On Success -> True
eMail On Failure -> True
eMail On Cancellation -> True
eMail On Start -> True
eMail On Download Failure -> True
eMail On Queueing -> True
Custom subject for Successful conversion ->
Custom subject for Failed conversion ->
Custom subject for Cancelled conversion ->
Custom subject for Start of conversion ->
Custom subject for Download Failure ->
Custom subject for Queueing conversion ->
Skip eMail Body for notifications -> False
Locale -> en-US
Temp Working Path ->
Archive Folder ->
Failed Folder ->
Space Check -> True
Custom Comskip Path ->
Custom profiles.conf ->
App Hang Timeout -> 300
Scan New Files Poll Period -> 60
Process Priority -> Normal
CPU Affinity -> 0
Engine Running -> True
Subtitle Cut Segment Incremental Offset -> 0
Minimum Segment Size (seconds) -> 4
Local Server Port -> 23332
UPnP Enabled -> False
Firewall Exception Enabled -> False
INFORMATION> --> Task -> Convert to MP4
Profile -> MP4 Normal
Source File -> C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
Relative Source Path -> C:\Users\julia\Downloads
Destination Path -> C:\Users\Public\Videos
Working Path -> C:\Program Files\MCEBuddy2x\working0
Fallback Destination -> False
Skip ReProcessing -> False
Check Reprocessing History -> False
Auto Increment Filename -> False
Add to iTunes Library -> False
Add to WMP Library -> False
Max Width -> 1920
Quality Multipltier -> 1
FPS ->
Auto DeInterlacing -> True
Prefer Hardware Encoding -> True
Use GPU Brands -> Any
Volume Multipltier -> 0
DRC -> True
Force Stereo -> True
Encoder Select Best Audio Track -> True
Profile Audio Language ->
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
Closed Captions Offset -> 0
Embed Subtitles -> False
Embed Chapters -> False
Strict Processing -> False
Commercial Removal -> Comskip
Custom Comskip INI Path ->
Search Ad markers from chapters -> True
Task Commercial Skip Cut -> False
Keep Advertisements -> False
Download Series Details -> True
Download Banner -> True
Overwrite metata from Title -> False
Overwrite metata from Internet -> Default
Prioritize matching by Original Broadcast Date -> False
Force Show Type -> Default
Write Metadata -> True
Rename by Series -> True
Alt Rename by Series -> True
Custom Rename by Series ->
Rename Only -> False
File Selection Pattern ->
Show Selection Pattern ->
Channel Selection Pattern ->
Show Type Selection -> Default
Codec Type Selection -> Any
DRM Type Selection -> All
File Size Comparator -> LessThan
File Size Threshold -> 0
Video Bitrate Comparator -> LessThan
Video Bitrate Threshold (Kbps) -> 0
Monitor Tasks Selection ->
Insert at Top of Queue -> False
Extract XML -> False
Disable Cropping -> True
Skip Copying Original File for Backup -> False
Skip Remuxing Original File to TS -> False
Ignore Copy Protection -> False
TiVO MAK Key ->
Destination Path Domain Name ->
Destination Path User Name -> Guest
Destination Path Password ->
Task Enabled -> True
INFORMATION> --> Max Concurrent Jobs -> 1
INFORMATION> --> Monitor Root Relative SubFolder Path -> C:\Users\julia\Downloads
INFORMATION> --> Commercial Skip Cut (profile (CommercialSkipCut) + task) -> False
INFORMATION> --> Auto DeInterlacing (profile (AutoDeinterlace) + task) -> True
INFORMATION> --> Pre-Conversion Commercial Remover (PreConversionCommercialRemover) -> True
INFORMATION> --> Copy LOG File (CopyLogFile) -> False
INFORMATION> --> Copy PROPERTIES file (CopyPropertiesFile) -> False
INFORMATION> --> Free Space Check -> True
INFORMATION> --> Locale Language -> ENG
INFORMATION> --> .NET Framework Version -> 4.0, Service Pack -> 0
INFORMATION> 2021-03-23T22:07:04 MCEBuddy.Engine.ConversionJob --> Current System language is English (United States) (eng)
INFORMATION> 2021-03-23T22:07:04 MCEBuddy.Engine.ConversionJob --> Converting file -> C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
--> Dumping complete information about the file C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
2021-03-23T22:07:04 MCEBuddy.AppWrapper.Base --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:07:04 MCEBuddy.AppWrapper.Base --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -i "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg"
2021-03-23T22:07:04 MCEBuddy.AppWrapper.Base --> UI Session Admin Process : False
2021-03-23T22:07:04 MCEBuddy.AppWrapper.Base --> Setting process priority to Normal
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> [h264 @ 000001edd437fe80] non-existing PPS 0 referenced
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Last message repeated 1 times
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> [h264 @ 000001edd437fe80] decode_slice_header error
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> [h264 @ 000001edd437fe80] no frame!
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Input #0, mpegts, from 'C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg':
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Duration: 00:37:13.82, start: 7646.081367, bitrate: 3688 kb/s
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Program 1
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Stream #0:0[0x101]: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 153 kb/s
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Stream #0:1[0x102]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1920x1080, Closed Captions, 59.94 tbr, 90k tbn, 96k tbc
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Stream #0:2[0x103]: Data: timed_id3 (ID3 / 0x20334449)
2021-03-23T22:07:06 MCEBuddy.AppWrapper.Base --> Unsupported codec with id 100358 for input stream 2
--> Process exited with code 0
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.Engine.ConversionJob --> Running custom commands
2021-03-23T22:07:08 MCEBuddy.Transcode.CustomCommand --> Engine running as service, enabling PreMetaCustomCommandUISession, since PreMetaCustomCommandShowWindow is enabled
2021-03-23T22:07:08 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
PreMetaCustomCommandPath =
PreMetaCustomCommandParameters =
PreMetaCustomCommandHangPeriod = 300
PreMetaCustomCommandCritical = False
PreMetaCustomCommandUISession = True
PreMetaCustomCommandShowWindow = True
PreMetaCustomCommandExitCodeCheck = False
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2021-03-23T22:07:08 MCEBuddy.Engine.ConversionJob --> Finished pre metadata custom command, source file size [KB] 1,005,856.00
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.Engine.ConversionJob --> Getting show information and banner from Internet sources
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Extracting metadata from file -> C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
--> Checking for SiliconDust meta tags
--> Starting to extract payload from TS file, upto 64 TS packets will be processed
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Video Tags extracted ->
Title:
SubTitle:
Description:
Network:
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 0
Episode: 0
Banner:
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
Is Movie: False
Is Sports: False
OriginalBroadcastDateTime: 1900-01-01T00:00:00
RecordedDateTime: 1900-01-01T00:00:00
SeriesPremiereDate: 1900-01-01T00:00:00
CopyProtected: False
SageTV FileID:
SageTV MediaFileID:
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Trying to match nPVR/SiliconDust/FlixGrab series showname -> The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Looking for Season/Episode information in text
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Pattern 1, Found Season/Episode information in text, Season:2, Episode:4
--> Looking for Premiere Year information in text
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Successfully matched nPVR/SiliconDust/FlixGrab series filename metadata
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Video Tags extracted from file/name metadata ->
Title: The New Adventures of Old Christine
SubTitle: 2006-10-09 Oh God Yes 2021-03-23-0127
Description:
Network:
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 2
Episode: 4
Banner:
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
Is Movie: False
Is Sports: False
SageTV FileID:
SageTV MediaFileID:
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Checking for metadata title and ID correction
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Checking for metadata type correction
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Downloading Series details
2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Overwrite title from internet -> Default
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Recording Type Show
INFORMATION> 2021-03-23T22:07:08 MCEBuddy.MetaData.VideoMetaData --> Checking TheTVDB
--> Looking for Episode name match on TVDB using language en
--> Looking for Episode name match on TVDB using language da
--> Looking for Episode name match on TVDB using language fi
--> Looking for Episode name match on TVDB using language nl
--> Looking for Episode name match on TVDB using language de
--> Looking for Episode name match on TVDB using language it
--> Looking for Episode name match on TVDB using language es
--> Looking for Episode name match on TVDB using language fr
--> Looking for Episode name match on TVDB using language pl
--> Looking for Episode name match on TVDB using language hu
--> Looking for Episode name match on TVDB using language el
--> Looking for Episode name match on TVDB using language tr
--> Looking for Episode name match on TVDB using language ru
--> Looking for Episode name match on TVDB using language he
--> Looking for Episode name match on TVDB using language ja
--> Looking for Episode name match on TVDB using language pt
--> Looking for Episode name match on TVDB using language zh
--> Looking for Episode name match on TVDB using language cs
--> Looking for Episode name match on TVDB using language sl
--> Looking for Episode name match on TVDB using language hr
--> Looking for Episode name match on TVDB using language ko
--> Looking for Episode name match on TVDB using language sv
--> Looking for Episode name match on TVDB using language no
--> No match found on TVDB for Episode Name
--> No original broadcast date time
--> Subtitle present, cannot match by season or episode number
--> No match found, checking for special characters in the Title
WARNING> 2021-03-23T22:07:11 MCEBuddy.MetaData.VideoMetaData --> TheTVDB failed
INFORMATION> 2021-03-23T22:07:11 MCEBuddy.MetaData.VideoMetaData --> Checking TV.com
--> No match found on TV.com
--> Invalid original broadcast date to match on TV.com
--> Subtitle present, cannot match by season or episode number on TV.com
WARNING> 2021-03-23T22:07:12 MCEBuddy.MetaData.VideoMetaData --> TV.com failed
INFORMATION> 2021-03-23T22:07:12 MCEBuddy.MetaData.VideoMetaData --> Checking TMDB
--> No match found by episode name on TMDB
--> No match found on TMDB Series
WARNING> 2021-03-23T22:07:12 MCEBuddy.MetaData.VideoMetaData --> TMDB failed
INFORMATION> 2021-03-23T22:07:12 MCEBuddy.MetaData.VideoMetaData --> Checking IMDB
--> Searching IMDB Series and overwrite metadata: False
--> Searching IMDB for Series Title match
--> IMDB search titles found -> 1
--> Total unique AKA's for IMDBId tt0462128 -> 15
--> Matched Series title -> The New Adventures of Old Christine
--> Matched information -> Type: TVSeries
Series Name:
SeriesPremiereDate: 2006-03-13T00:00:00
Total Years: 0
Total Seasons: 5
Season: 0
Episode: 0
IMDB Id: tt0462128
Description: A divorced mom tries to keep pace with everyone around her.
Genres: Comedy
Parental Rating: TV-PG
Actors: Julia Louis-Dreyfus;Clark Gregg;Hamish Linklater;Trevor Gagnon
Banner URL: https://m.media-amazon.com/images/M/MV5BMTFkNDJjNDctZDg5Yi00MTU0LTg3Y2EtYzhkMWZjYjlkNmFiXkEyXkFqcGdeQXVyMTkzODUwNzk@.V1_UY268_CR19,0,182,268_AL.jpg
--> Total Episodes in Season 5 -> 21
--> Total Episodes in Season 4 -> 22
--> Total Episodes in Season 3 -> 10
--> Total Episodes in Season 2 -> 22
--> Total Episodes in Season 1 -> 13
--> No match found on IMDB Series
--> Invalid original broadcast date to match on IMDB
--> Subtitle present, cannot match by season or episode number on IMDB
WARNING> 2021-03-23T22:07:49 MCEBuddy.MetaData.VideoMetaData --> IMDBApi failed
2021-03-23T22:07:49 MCEBuddy.MetaData.VideoMetaData --> Updated Video Tags extracted after downloading details ->
Description:
Network:
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 2
Episode: 4
Banner: C:\Program Files\MCEBuddy2x\cache\The New Adventures of Old Christine.jpg
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
Is Movie: False
Is Sports: False
SageTV FileID:
SageTV MediaFileID:
INFORMATION> 2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Running custom commands
2021-03-23T22:07:49 MCEBuddy.Transcode.CustomCommand --> Engine running as service, enabling PreCustomCommandUISession, since PreCustomCommandShowWindow is enabled
2021-03-23T22:07:49 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
PreCustomCommandPath =
PreCustomCommandParameters =
PreCustomCommandHangPeriod = 300
PreCustomCommandCritical = False
PreCustomCommandUISession = True
PreCustomCommandShowWindow = True
PreCustomCommandExitCodeCheck = False
INFORMATION> 2021-03-23T22:07:49 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Finished pre remuxing custom command, source file size [KB] 1,005,856.00
INFORMATION> 2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Checking for disk space
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> File size -> 0.959259 GB
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Destination space -> 145.3881 GB
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Working space -> 145.3881 GB
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Total active conversions file sizes -> 0.959259033203125 GB
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Required free space -> 2.877777 GB
2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Max concurrent conversion jobs -> 1
INFORMATION> 2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Checking for SRT File
INFORMATION> 2021-03-23T22:07:49 MCEBuddy.Engine.ConversionJob --> Checking for EDL, EDLP, VPRJ or DTB XML files
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Force Remuxsupp (UseWTVRemuxsupp) : False
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Force WTV Streams Remuxing (ForceWTVStreamsRemuxing) : False
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Disable DVRMS Streams Remuxing (DisableDVRMSStreamsRemuxing) : False
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Allow H264 Copy Remuxing (AllowH264CopyRemuxing) (default: true) : True
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Allow H265 Copy Remuxing (AllowH265CopyRemuxing) (default: true if not using ShowAnalyzer or MEncoder) : True
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Allow All Video codec formats Copy Remuxing (AllowAllCopyRemuxing) (default: false) : False
2021-03-23T22:07:49 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Reading Recording file C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg media information
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg"
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688147323,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.081367",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201039338,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.770422",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x102",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688153317,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.147967",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201037980,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.755333",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 2,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "timed_id3",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "timed ID3 metadata",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "data",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "ID3 ",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x20334449",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x103",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688156321,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.181344",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 3,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.821933",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1029996544",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3688732",
2021-03-23T22:07:49 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:07:51 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
Duration (s) -> 2233.822
Color format -> yuv420p
Height (pixels) -> 1080
Width (pixels) -> 1920
Storage aspect ratio (SAR) ->
Display aspect ratio (DAR) ->
Video bitrate (bps) -> 3688732
Frames per seconds (FPS) -> 59.94
Video stream PID -> 258
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Sampling frequency (Hz) -> 48000
Audio channels -> 2
Bits per sample -> 0
Audio bitrate (kb/s) -> 153375
Audio stream PID -> 257
Impaired track (audio or visual) -> False
CHAPTER INFO ->
--> Checking for donator version of Comskip
2021-03-23T22:07:51 MCEBuddy.AppWrapper.Comskip --> Launching process C:\Program Files\MCEBuddy2x\comskip\comskip.exe
2021-03-23T22:07:51 MCEBuddy.AppWrapper.Comskip --> Process arguments -h
2021-03-23T22:07:51 MCEBuddy.AppWrapper.Comskip --> UI Session Admin Process : True
2021-03-23T22:07:51 MCEBuddy.AppWrapper.Comskip --> Starting process as a UISession process with Admin privileges. This requires atleast 1 user to be logged into the system (remote desktop or locally)
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Setting process priority to Normal
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> The commandline used was:
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> "C:\Program Files\MCEBuddy2x\comskip\comskip.exe" -h
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Usage:
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> comskip [-h|--help] [-w|--debugwindow] [-n|--playnice] [--zpcut] [--zpchapter] [--scf] [--videoredo] [--videoredo3] [--csvout] [--quality] [--plist] [-m|--demux] [--hwassist] [--threads=] [-p|--pid=] [-t|--ts] [-d|--detectmethod=] [-v|--verbose=] [-u|--dump=] [-s|--play] [--timing] [-q|--quiet] [--ini=] [--logo=] [--cut=] [--output=] [--output-filename=] [--selftest=] []
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -h, --help Display syntax
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -w, --debugwindow Show debug window
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -n, --playnice Slows detection down
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --zpcut Outputs a ZoomPlayer cutlist
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --zpchapter Outputs a ZoomPlayer chapter file
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --scf Outputs a simple chapter file for mkvmerge
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --videoredo Outputs a VideoRedo cutlist
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --videoredo3 Outputs a VideoRedo3 cutlist
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --csvout Outputs a csv of the frame array
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --quality Outputs a csv of false detection segments
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --plist Outputs a mac-style plist for addition to an EyeTV archive as the 'markers' property
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -m, --demux Demux the input into elementary streams
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --hwassist Activate Hardware Assisted video decoding
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --threads= The number of threads to use
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -p, --pid= The PID of the video in the TS
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -t, --ts The input file is a Transport Stream
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -d, --detectmethod= An integer sum of the detection methods to use
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -v, --verbose= Verbose level
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -u, --dump= Dump the cutscene at this frame number
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -s, --play Play the video
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --timing Dump the timing into a file
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> -q, --quiet Not output logging to the console window
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --ini= Ini file to use
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --logo= Logo file to use
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --cut= CutScene file to use
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --output= Folder to use for all output files
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --output-filename= Filename base to use for all output files
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> --selftest= Execute a selftest
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Input file
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Output folder for cutlist
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Detection Methods
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 1 - Black Frame
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 2 - Logo
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 4 - Scene Change
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 8 - Resolution Change
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 16 - Closed Captions
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 32 - Aspect Ratio
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 64 - Silence
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 128 - CutScenes
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> 255 - USE ALL AVAILABLE
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Comskip 0.82.003, made using ffmpeg
2021-03-23T22:07:52 MCEBuddy.AppWrapper.Comskip --> Donator build
--> Process exited with code 2
INFORMATION> --> Comskip version : DONATOR
INFORMATION> 2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> AllowH264CopyRemuxing will run fast for commercial detection, using donator version of Comskip
INFORMATION> 2021-03-23T22:07:54 MCEBuddy.Engine.ConversionJob --> Remuxing recording
INFORMATION> 2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Fast Remuxing
2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Reading MediaInfo from C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Video FPS : 0
2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Reading FFMPEG info from C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
INFORMATION> 2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Copy remux loop 0
2021-03-23T22:07:54 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Verifying Recorded file audio streams for Zero Channel Audio
--> Checking for 0 Channel Audio Tracks in C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg
2021-03-23T22:07:54 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:07:54 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg"
2021-03-23T22:07:54 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:07:54 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688147323,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.081367",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201039338,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.770422",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x102",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688153317,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.147967",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201037980,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.755333",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 2,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "timed_id3",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "timed ID3 metadata",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "data",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "ID3 ",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x20334449",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x103",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688156321,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.181344",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 3,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.821933",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1029996544",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3688732",
2021-03-23T22:07:55 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
CHAPTER INFO ->
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffmpeg.exe
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -y -i "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg" -ss 0 -vcodec copy -acodec copy -map 0:a -map 0:1 -f mpegts "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts"
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> UI Session Admin Process : True
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Starting process as a UISession process with Admin privileges. This requires atleast 1 user to be logged into the system (remote desktop or locally)
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Setting process priority to Normal
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> [h264 @ 0000026c9df2cbc0] non-existing PPS 0 referenced
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Last message repeated 1 times
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> [h264 @ 0000026c9df2cbc0] decode_slice_header error
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> [h264 @ 0000026c9df2cbc0] no frame!
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Input #0, mpegts, from 'C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg':
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Duration: 00:37:13.82, start: 7646.081367, bitrate: 3688 kb/s
--> Video duration=2233.82
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Program 1
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:0[0x101]: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 153 kb/s
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:1[0x102]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1920x1080, Closed Captions, 59.94 tbr, 90k tbn, 96k tbc
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:2[0x103]: Data: timed_id3 (ID3 / 0x20334449)
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Output #0, mpegts, to 'C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts':
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Metadata:
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> encoder : Lavf58.33.100
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:0: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 153 kb/s
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:1: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1920x1080, q=2-31, 59.94 tbr, 90k tbn, 90k tbc
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream mapping:
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:0 -> #0:0 (copy)
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Stream #0:1 -> #0:1 (copy)
2021-03-23T22:07:57 MCEBuddy.AppWrapper.FFmpeg --> Press [q] to stop, [?] for help
2021-03-23T22:07:58 MCEBuddy.AppWrapper.FFmpeg --> frame=10252 fps=0.0 q=-1.0 size= 155648kB time=00:05:42.20 bitrate=3726.1kbits/s speed= 664x
2021-03-23T22:07:58 MCEBuddy.AppWrapper.FFmpeg --> frame=17055 fps=16542 q=-1.0 size= 265472kB time=00:09:46.54 bitrate=3707.7kbits/s speed= 569x
2021-03-23T22:07:59 MCEBuddy.AppWrapper.FFmpeg --> frame=20980 fps=13588 q=-1.0 size= 330240kB time=00:12:08.86 bitrate=3711.7kbits/s speed= 472x
2021-03-23T22:07:59 MCEBuddy.AppWrapper.FFmpeg --> frame=27086 fps=13152 q=-1.0 size= 423424kB time=00:15:32.64 bitrate=3719.2kbits/s speed= 453x
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> frame=34250 fps=13301 q=-1.0 size= 534016kB time=00:19:42.47 bitrate=3699.6kbits/s speed= 459x
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026c9df28f40] DTS 809259968 < 809512222 out of order
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 121629859, current: 121629859; changing to 121629860. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 122147073, current: 122147073; changing to 122147074. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 122664287, current: 122664287; changing to 122664288. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 123181501, current: 123181501; changing to 123181502. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 123698715, current: 123698715; changing to 123698716. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 124215929, current: 124215929; changing to 124215930. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:00 MCEBuddy.AppWrapper.FFmpeg --> frame=39701 fps=12904 q=-1.0 size= 613376kB time=00:23:17.40 bitrate=3595.8kbits/s speed= 454x
2021-03-23T22:08:01 MCEBuddy.AppWrapper.FFmpeg --> frame=46026 fps=12861 q=-1.0 size= 709632kB time=00:26:48.39 bitrate=3614.4kbits/s speed= 449x
2021-03-23T22:08:01 MCEBuddy.AppWrapper.FFmpeg --> frame=49844 fps=12210 q=-1.0 size= 767744kB time=00:28:56.01 bitrate=3622.9kbits/s speed= 425x
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> frame=51933 fps=11334 q=-1.0 size= 800256kB time=00:30:14.41 bitrate=3613.1kbits/s speed= 396x
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026c9df28f40] DTS 855439411 < 855691665 out of order
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 170912585, current: 170912585; changing to 170912586. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 171429799, current: 171429799; changing to 171429800. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 171947013, current: 171947013; changing to 171947014. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 172464227, current: 172464227; changing to 172464228. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 172981441, current: 172981441; changing to 172981442. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 173498655, current: 173498655; changing to 173498656. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 174015869, current: 174015869; changing to 174015870. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 174533083, current: 174533083; changing to 174533084. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 175050297, current: 175050297; changing to 175050298. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 175567511, current: 175567511; changing to 175567512. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> [mpegts @ 0000026ca479b040] Non-monotonous DTS in output stream 0:1; previous: 176084725, current: 176084725; changing to 176084726. This may result in incorrect timestamps in the output file.
2021-03-23T22:08:02 MCEBuddy.AppWrapper.FFmpeg --> frame=55662 fps=10952 q=-1.0 size= 853760kB time=00:33:06.99 bitrate=3519.9kbits/s speed= 391x
2021-03-23T22:08:03 MCEBuddy.AppWrapper.FFmpeg --> frame=59480 fps=10633 q=-1.0 size= 911872kB time=00:35:14.42 bitrate=3532.9kbits/s speed= 378x
2021-03-23T22:08:03 MCEBuddy.AppWrapper.FFmpeg --> frame=62393 fps=10238 q=-1.0 size= 956416kB time=00:36:51.65 bitrate=3542.6kbits/s speed= 363x
2021-03-23T22:08:04 MCEBuddy.AppWrapper.FFmpeg --> frame=65736 fps=9963 q=-1.0 size= 1006080kB time=00:38:43.18 bitrate=3547.6kbits/s speed= 352x
2021-03-23T22:08:04 MCEBuddy.AppWrapper.FFmpeg --> frame=65984 fps=9946 q=-1.0 Lsize= 1009985kB time=00:38:51.43 bitrate=3548.8kbits/s speed= 351x
2021-03-23T22:08:04 MCEBuddy.AppWrapper.FFmpeg --> video:935235kB audio:35616kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 4.030827%
--> FFMpeg output file size [KB] -> 1,009,985.00
2021-03-23T22:08:06 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Original file size [KB] -> 1,005,856.00
2021-03-23T22:08:06 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Remuxed file size [KB] -> 1,009,985.00
--> Checking for 0 Channel Audio Tracks in C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts
2021-03-23T22:08:06 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:08:06 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts"
2021-03-23T22:08:06 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:08:06 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x100",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 126000,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.400000",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209828135,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.423722",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 134998,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.499978",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209827613,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.417922",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 2,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.517900",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1034224660",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3548674",
2021-03-23T22:08:07 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
Duration (s) -> 2331.518
Video bitrate (bps) -> 3548674
Video stream PID -> 257
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
Audio stream PID -> 256
CHAPTER INFO ->
--> Average rate of dropped frames : 0.00
--> Average rate of duplicate frames : 0.00
2021-03-23T22:08:09 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Original file size [KB] -> 1,005,856.00
2021-03-23T22:08:09 MCEBuddy.RemuxMediaCenter.RemuxMCERecording --> Remuxed file size [KB] -> 1,009,985.00
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts"
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x100",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 126000,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.400000",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209828135,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.423722",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 134998,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.499978",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209827613,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.417922",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 2,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.517900",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1034224660",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3548674",
2021-03-23T22:08:09 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:08:12 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
CHAPTER INFO ->
2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Remuxing: Percentage Complete 100
2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Was remuxed video recoded : False
2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Remuxed video file : C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts
2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Finished Remuxing, file size [KB] 1,009,985.00
INFORMATION> 2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Trimming video recording
2021-03-23T22:08:12 MCEBuddy.Transcode.TrimVideo --> Start Trim : 0
2021-03-23T22:08:12 MCEBuddy.Transcode.TrimVideo --> Stop Trim : 0
2021-03-23T22:08:12 MCEBuddy.Transcode.TrimVideo --> Video File : C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts
2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Trimming successful, setting trim parameters to 0 to avoid retrimming
INFORMATION> 2021-03-23T22:08:12 MCEBuddy.Engine.ConversionJob --> Analyzing video information
INFORMATION> 2021-03-23T22:08:12 MCEBuddy.VideoProperties.VideoInfo --> Reading MediaInfo from C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts
2021-03-23T22:08:12 MCEBuddy.VideoProperties.VideoInfo --> Video Codec : avc
2021-03-23T22:08:13 MCEBuddy.VideoProperties.VideoInfo --> Audio Codec : aac lc sbr
2021-03-23T22:08:13 MCEBuddy.VideoProperties.VideoInfo --> Video FPS : 0
2021-03-23T22:08:14 MCEBuddy.VideoProperties.VideoInfo --> Video Width : 1920
2021-03-23T22:08:14 MCEBuddy.VideoProperties.VideoInfo --> Video Height : 1080
2021-03-23T22:08:14 MCEBuddy.VideoProperties.VideoInfo --> Video Duration : 2331.401
2021-03-23T22:08:15 MCEBuddy.VideoProperties.VideoInfo --> Audio Delay : -0.1
INFORMATION> 2021-03-23T22:08:15 MCEBuddy.VideoProperties.VideoInfo --> Supplementing Media information using FFMPEG
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts"
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x100",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 126000,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.400000",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209828135,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.423722",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 134998,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.499978",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209827613,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.417922",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 2,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.517900",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1034224660",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3548674",
2021-03-23T22:08:15 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
--> Process exited with code 0
2021-03-23T22:08:17 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
CHAPTER INFO ->
2021-03-23T22:08:17 MCEBuddy.VideoProperties.VideoInfo --> Only one audio track present, Audio Stream 0, Audio Track 0, Channels 2, Codec aac Impaired False
INFORMATION> 2021-03-23T22:08:17 MCEBuddy.VideoProperties.VideoInfo --> Reading Original File Media information
2021-03-23T22:08:17 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:08:17 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg"
2021-03-23T22:08:17 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:08:17 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688147323,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.081367",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201039338,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.770422",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x102",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688153317,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.147967",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 201037980,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.755333",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 2,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "timed_id3",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "timed ID3 metadata",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "data",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "ID3 ",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x20334449",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x103",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 688156321,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "7646.181344",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Users\julia\Downloads\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.mpg",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 3,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2233.821933",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1029996544",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3688732",
2021-03-23T22:08:18 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
CHAPTER INFO ->
INFORMATION> 2021-03-23T22:08:20 MCEBuddy.VideoProperties.VideoInfo --> Skipping crop information
INFORMATION> 2021-03-23T22:08:20 MCEBuddy.Engine.ConversionJob --> Advertisement scan
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -v quiet -print_format json -show_format -show_streams -show_chapters -i "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts"
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> UI Session Admin Process : False
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> Setting process priority to Normal
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> {
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "streams": [
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "aac",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "AAC (Advanced Audio Coding)",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "HE-AAC",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "audio",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "1/48000",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[15][0][0][0]",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x000f",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_fmt": "fltp",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "sample_rate": "48000",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channels": 2,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "channel_layout": "stereo",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_sample": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x100",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "0/0",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "avg_frame_rate": "0/0",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "time_base": "1/90000",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 126000,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.400000",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209828135,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.423722",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "153375",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "disposition": {
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "default": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "dub": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "original": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "comment": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "lyrics": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "karaoke": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "forced": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "hearing_impaired": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "visual_impaired": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "clean_effects": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "attached_pic": 0,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "timed_thumbnails": 0
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> }
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> },
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "index": 1,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_name": "h264",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "profile": "High",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_type": "video",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_time_base": "0/2",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag_string": "[27][0][0][0]",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "codec_tag": "0x001b",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "width": 1920,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "height": 1080,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_width": 1920,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "coded_height": 1088,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "has_b_frames": 2,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "pix_fmt": "yuv420p",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "level": 40,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_range": "tv",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_space": "bt709",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_transfer": "bt709",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "color_primaries": "bt709",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chroma_location": "center",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "field_order": "progressive",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "refs": 1,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "is_avc": "false",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nal_length_size": "0",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "id": "0x101",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "r_frame_rate": "60000/1001",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_pts": 134998,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "start_time": "1.499978",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration_ts": 209827613,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.417922",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bits_per_raw_sample": "8",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ],
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "chapters": [
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format": {
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "filename": "C:\Program Files\MCEBuddy2x\working0\The New Adventures of Old Christine S02E04 2006-10-09 Oh God Yes 2021-03-23-0127.ts",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_streams": 2,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "nb_programs": 1,
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_name": "mpegts",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "duration": "2331.517900",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "size": "1034224660",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "bit_rate": "3548674",
2021-03-23T22:08:20 MCEBuddy.AppWrapper.FFmpegMediaInfo --> "probe_score": 50
2021-03-23T22:08:23 MCEBuddy.AppWrapper.FFmpegMediaInfo -->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
Color format -> yuv420p
Height (pixels) -> 1080
Width (pixels) -> 1920
Storage aspect ratio (SAR) ->
Display aspect ratio (DAR) ->
Frames per seconds (FPS) -> 59.94
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Sampling frequency (Hz) -> 48000
Audio channels -> 2
Bits per sample -> 0
Audio bitrate (kb/s) -> 153375
Audio stream PID -> 257
Impaired track (audio or visual) -> False
CHAPTER INFO ->
VIDEO TRACK INFO ->
Video stream -> 1
Video codec -> h264
AUDIO TRACK INFO ->
Audio stream -> 0
Audio language ->
Audio codec -> aac
Audio channels -> 2
CHAPTER INFO ->
ROR> 2021-03-23T22:27:52 MCEBuddy.Engine.ConversionJob --> Advertisement scan failed
INFORMATION> 2021-03-23T22:27:52 MCEBuddy.Engine.ConversionJob -->
--> Performance Metrics for the Current Conversion
--> Working video pre-conversion duration (hh:mm:ss) -> 00:38:51
2021-03-23T22:27:52 MCEBuddy.Engine.ConversionJob --> Original file size [KB] 0.00
--> <Start At Date/Time> <Duration (hh:mm:ss)>
--> <03/23/2021 22:07:08> <00:00:00>
--> <03/23/2021 22:07:08> <00:00:40>
--> <03/23/2021 22:07:49> <00:00:00>
--> <03/23/2021 22:07:49> <00:00:05>
--> <03/23/2021 22:07:54> <00:00:17>
--> <03/23/2021 22:08:12> <00:00:00>
--> <03/23/2021 22:08:12> <00:00:08>
--> <03/23/2021 22:08:20> <00:19:31>
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:20:43
Posting the log like this is not a good Idea makes it hard to search (gave me a headache)
.... I see that Comskip failed so it will not process any further ...
If you are using Channels DVR recordings ... An EDL is already available ... On your flash Drive copy the JSON the MPG and EDL file. That way you will have all the Episode data and it will not run Comskip again because you have an EDL. Process the MPG not the Json.
sorry about that! I have only used channels dvr for less than a year and MCEbuddy less than a week. The weird thing is once I went through and checked my settings, it started processing tv shows. However the bad news is that it cuts the episodes down to about 19 minutes and I want to see them around 22 mins. It seems that for some reason, TVLand has old sitcoms run in 36-minute blocks, so I am trying to see if I can find an airing that 30 minutes and see if that cuts it down - i have a hunch the program got confused to see a 36-minute sitcom. To make matters even more frustrating, custom cuts crapped out on me. I tried a new file and a backup of a file I had tried yesterday and both said error - could not be processed or something like that. I am also testing a 30 minute show recorded straight off my antenna (not TVE) and see if those cut down to 22 minutes.
Also why do I need to process JSON and EDL files? I thought you said they wouldn't work with MCEBuddy? Sorry if that's a dumb question!!
update - the show I ran through MCEbuddy straight off my antenna converted at 16mins, even less than the 19 mins from the cable channels.
They do work just not to process as long as the EDL file and JSON file are alongside the MPG ... when you process the MPG MCEBUDDY will look to see f there is a JSON or EDL file ... It will use the JSON to get the Episode information like genre description etc... It will use the EDL and not run Comskip again.
\This is how MCEBUDDY use the JSON ...
INFORMATION> 2021-03-16T08:52:49 MCEBuddy.MetaData.FileExtractMetadata --> Extracting JSON Tags
2021-03-16T08:52:49 MCEBuddy.MetaData.FileExtractMetadata --> Extracting Channels DVR metadata
2021-03-16T08:52:49 MCEBuddy.MetaData.FileExtractMetadata --> JSON Metadata source -> Channels DVR
--> Extracted JSON tags:
Title: Law & Order: Criminal Intent
SubTitle: Conscience
Description: Detectives probe the death of a woman found poisoned and in a pool.
Network:
Network Affiliate:
Parental Rating:
Media Credits:
Genres: Crime drama
Season: 3
Episode: 17
Banner:
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
Is Movie: False
Is Sports: False
OriginalBroadcastDateTime: 2004-03-28T00:00:00
RecordedDateTime: 2021-03-16T12:01:00
SeriesPremiereDate: 2001-09-30T00:00:00
CopyProtected: False
SageTV FileID:
SageTV MediaFileID:
so when I convert the videos should I put them in a folder, the mpg, edl, and json? I just tried running edl and that did not work. But why does it work if you take it from Custom Cuts? I'm assuming that the issue is more complicated because my Channels server is not on the same computer as the MCEbuddy? I should probably convert one of my hard drives to EXFat so I could use them easily on both folders too...It might not end up working properly for TV but if I can at least get it working for movies, I'll be slightly happy.
