New User Help Please - DVR / Web Player not working
Hello. I set this up and am able to watch on iOS devices with no issues. I can set programs to record but they fail. Checking the log i get some variation of the following:
2024/09/28 21:03:08.109916 [DVR] Error running job 1727569232-ch2.1 College Football: could not start stream on channels=[2.1]: GET: http://10.0.0.150:80/auto/v2.1: 404 Not Found
2024/09/28 21:03:27.381366 [DVR] Starting job 1727573100-ch8.1 Midsomer Murders on ch=[8.1]
2024/09/28 21:03:27.506979 [ERR] Failed to start stream on channel 8.1 via 10951A18: GET: http://10.0.0.150:80/auto/v8.1: 404 Not Found
I get a similar error if I try to play live tv in the web browser.
I'm set up on a Mac Book air with external storage. Server status doesn't indicate any problems. Any suggestions? Thanks in advance!
This is your problem. What are you using for your source?
I am curious about how you added the tuners to the server. Typically HDHR tuners serve their streams over port 5004; port 80 is only for the tuner's status/lineup pages.
HD HomeRun. It wasn't able to find it automatically so I had to add the IP address manually. I'm guessing I did something wrong at that point.
Running Sequoia?
Check permissions for channels dvr
Apple menu → System Settings → Privacy & Security → Local Network
https://forum.silicondust.com/forum/viewtopic.php?p=401040#p401040
That may be why Channels DVR didn't see your HDHR tuner.
You need to remove the :80 port from the ip address.
Thanks all! I got it sorted but would not have figured it out without your help!
You likely need to enable permissions for Local Network Discovery for the DVR server on your Mac. You are usually prompted for this on first run, but it often is not presented. You need to manually enable this in the macOS System Settings.
