I just got a HDHomeRun FLEX DUO and attached a USB HDD to the port. Can this setup be used by Channels DVR, or do I need to have a separate NAS/Channels Server setup?
I want to use the channels app, but I only need a small amount of storage for a show or two (primarily recent sports events) so I bought a small cheap USB drive. I was hoping to not go through a more complicated setup since my needs are simple.
Thank you!
