The newest build doesn't seem to be loading. Now using 2019.06.25.0534. when I download the newest update it doesn't load or give me web access.
Is anyone else having issues with the latest DVR build?
Can you see if there are errors in c:\programdata\channelsdvr\data\channels-dvr.log
I just loaded the latest on my Synology 718+ and it seems to be fine.
Was able to update my Windows test DVR to 2019.06.25.2104 without any issue.
It now says Waiting to upgrade to 2019.06.25.2104...
I had to revert back to 2019 06.25.0534
Got it fixed. Was being block by a program. Now updated to latest version
