The next up display differently from each other totally a mess. If you click on NEXT up then next up in library and back and forth you get totally different views each time.
I cannot make sense of what you're saying.
Go into UP Next ... go back ... Go into Library look at UP next ... go back ... Click on up next it sometimes is sorted alphabetically.
Thanks. I messed this up yesterday with the fixes to TV and Movies view. Will fix.
No problem that is why we beta test.
Does it work in the latest beta now?
Yes thanks.
