Nfl gamepass question
Hi, i was just wondering, if there is any non iptv, and non hardware transcoding/capture way to get nfl gamepass on channelsdvr, i currently have gamepass through dazn, but if it can be done through another provider i would be willing to make the change. Thanks in advance!
just tagged you in the EPlus thread. Dev talked about DAZN support a while back.
there is no answer there brother
hello there is nothing there
