I get the following with YouTube TV yet. Anyone else?
"no login form found"
948fed51-ed66-44b7-9400-75c9ee788641 .
You should submit diagnostics from the DVR so the developers can see what's causing the problem
Still having problems logging in.
Submitted Log: 8fb44041-f484-4612-9500-58c9a89bc8ce
Snipet from Log:
2022/12/26 19:18:42.928167 [TVE] action=version product=Chrome/97.0.4692.56 jsVersion=9.7.106.18 protocol=1.3 revision=@04da6c66398ca50e603cc236a07dc7dfd3bbc750
2022/12/26 19:18:42.928881 [TVE] action=set_cookies domains=1 cookies=1
2022/12/26 19:18:42.931892 [TVE] action=mock
2022/12/26 19:18:42.938914 [TVE] action=navigate url=https://www.nfl.com/network/watch/nfl-network-live
2022/12/26 19:18:42.941135 [TVE] action=request type=Document method=GET url=https://www.nfl.com/network/watch/nfl-network-live
2022/12/26 19:18:42.941162 [TVE] action=auth_domain domain=www.nfl.com
2022/12/26 19:18:42.941168 [TVE] action=nflauth step=start
2022/12/26 19:18:43.350739 [TVE] action=wait_for_page
2022/12/26 19:18:51.222872 [TVE] action=error_response type=Fetch error=net::ERR_ABORTED url=https://www.facebook.com/x/oauth/status
2022/12/26 19:18:54.482121 [TVE] action=page_ready
2022/12/26 19:18:54.482168 [TVE] action=wait_for_page done=true reason=page_ready
2022/12/26 19:18:54.492719 [TVE] action=click_interstitial
2022/12/26 19:18:54.495754 [TVE] action=tvejs msg="nflSelect: path=/network/watch/nfl-network-live"
2022/12/26 19:18:54.541752 [TVE] action=wait_for_interstitial timeout=12s
2022/12/26 19:18:54.722337 [TVE] action=request type=Document method=GET url=https://www.nfl.com/activate/8FH728
2022/12/26 19:18:54.722373 [TVE] action=nflauth step=activate_start
2022/12/26 19:18:54.997405 [TVE] action=error_response type=Image error=net::ERR_ABORTED url=https://adb2waycm-atl.netmng.com/cm/
2022/12/26 19:18:57.543571 [TVE] action=error_response type=Fetch error=net::ERR_ABORTED url=https://googleads4.g.doubleclick.net/pcs/view
2022/12/26 19:18:58.375571 [TVE] action=error_response type=Fetch error=net::ERR_ABORTED url=https://securepubads.g.doubleclick.net/pcs/view
2022/12/26 19:19:03.294695 [TVE] action=request type=Fetch method=DELETE url=https://sp.auth.adobe.com/api/v1/logout
2022/12/26 19:19:03.901124 [TVE] action=error_response type=Fetch error=net::ERR_ABORTED url=https://www.facebook.com/x/oauth/status
2022/12/26 19:19:06.261863 [TVE] action=page_ready
2022/12/26 19:19:06.261910 [TVE] action=nflauth event=page_ready
2022/12/26 19:19:06.272086 [TVE] action=click_interstitial
2022/12/26 19:19:06.344720 [TVE] action=tvejs msg="nflSelect: path=/activate/8FH728"
2022/12/26 19:19:06.365935 [TVE] action=wait_for_interstitial timeout=12s
2022/12/26 19:19:07.430112 [TVE] action=request type=Fetch method=POST url=https://sp.auth.adobe.com/reggie/v1/NFL/regcode
2022/12/26 19:19:07.712594 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2022/12/26 19:19:07.838527 [TVE] action=request type=Document method=GET url=https://auth.hulu.com/oauth2/login
2022/12/26 19:19:15.049182 [TVE] action=page_ready
2022/12/26 19:19:15.049245 [TVE] action=wait_for_interstitial done=true reason=page_ready
2022/12/26 19:19:15.049266 [TVE] action=fill_form [email protected]
2022/12/26 19:19:15.078479 [TVE] action=wait_for_auth timeout=12s
2022/12/26 19:19:27.079173 [TVE] action=auth_timed_out
2022/12/26 19:19:27.079229 [TVE] action=screenshot
2022/12/26 19:19:27.208971 [TVE] action=screenshot size=36156
2022/12/26 19:19:27.209195 [TVE] action=capture_html
2022/12/26 19:19:27.217344 [TVE] action=capture_html size=97158
Still having authentication issues for provider Optimum Diags submitted 328b613f-db0f-41c2-a4f0-0e8e83fd050d
v2022.12.26.1705 FIXED: NFL Network issues for me as well. YouTubeTV
Working for me now on 2022.12.26.1705 using FubOTV
THANKS!!!!
v2022.12.26.1705 FIXED: NFL Network issues for me as well. Spectrum with Channels running on Windows.
v2022.12.26.1705 fixed my issues with YouTube TV as well!
One thing I've noticed, is when trying to auth using YTTV, I'm still getting the "no login form found" message.
However, before I scan the channels, TVE says chrome version is good.
After I scan, It says its out of date, this is repeatable.
ae2a8870-c1ac-4b3b-a69c-807b3bb93d5f
You might want to add to this thread (no acknowledgment from the devs yet)
Fixed for me on Hulu.
2022.12.26.1705 Fixed for both spectrum and YouTube tv. Thanks!
NFL Channel working with 2022.12.28.0400 for Spectrum on Mac OSX Monterey
Can confirm the same for Hotwire (same build and OS as well).
Still not working here with Hulu.
Whenever I do a rescan of NFL Network, I get a one-time verification code emailed to me from Hulu. Am I supposed to be able to enter this somewhere?
Version 2022.12.28.2233
Diagnostics d03f209e-7e12-475c-a4f1-fdcc2f6c40b8
Did you try this?
Yes, I've done that procedure several times over the past several days (delete "TV Everywhere" device in Hulu account, then delete and re-add source in Channels). NFL Network always failed. But...
Just tried it again and now NFL Network scans successfully when re-adding the source in Channels.
This was the first time I tried using the 2022.12.28.2233 pre-release.
Looks like this problem with NFL Network is back again. Running Channels (version 2023.04.04.2041 ) on 2012 mac mini (MacOS Monterey 12.6.4) with Spectrum TVE. Rescanned NFL Network and it passed the rescan, but still not viewable. Works fine when accessed through NFL.com.
Log:
2023/04/05 12:32:06.135278 [TNR] Opened connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:06.142611 [HLS] Starting live stream for channel 6192 from x.x.x.x (bitrate=3200)
2023/04/05 12:32:07.131200 [HLS] ffmpeg: ch6192-dANY-ipx.x.x.x-remux: Output file #0 does not contain any stream
2023/04/05 12:32:07.213712 [HLS] Couldn't generate stream playlist for ch6192-dANY-ipx.x.x.x: Stream stopped
2023/04/05 12:32:07.213799 [HLS] Stopping transcoder session ch6192-dANY-ipx.x.x.x
2023/04/05 12:32:07.215113 [TNR] Closed connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:07.215180 [ERR] Probe failed for live stream after 1.070186189s and 0 bytes
2023/04/05 12:32:07.975786 [TNR] Opened connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:07.982251 [HLS] Starting live stream for channel 6192 from 10.0.0.103 (bitrate=3200)
2023/04/05 12:32:08.962809 [HLS] ffmpeg: ch6192-dANY-ipx.x.x.x-remux: Output file #0 does not contain any stream
2023/04/05 12:32:09.003657 [HLS] Couldn't generate stream playlist for ch6192-dANY-ipx.x.x.x: Stream stopped
2023/04/05 12:32:09.003725 [HLS] Stopping transcoder session ch6192-dANY-ipx.x.x.x
2023/04/05 12:32:09.004917 [TNR] Closed connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:09.004993 [ERR] Probe failed for live stream after 1.019805593s and 0 bytes
2023/04/05 12:32:10.123853 [TNR] Opened connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:10.131439 [HLS] Starting live stream for channel 6192 from x.x.x.x (bitrate=3200)
2023/04/05 12:32:11.053710 [HLS] ffmpeg: ch6192-dANY-ipx.x.x.x-remux: Output file #0 does not contain any stream
2023/04/05 12:32:11.083473 [HLS] Couldn't generate stream playlist for ch6192-dANY-ipx.x.x.x: Stream stopped
2023/04/05 12:32:11.083570 [HLS] Stopping transcoder session ch6192-dANY-ipx.x.x.x
2023/04/05 12:32:11.084676 [TNR] Closed connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:11.084777 [ERR] Probe failed for live stream after 951.08836ms and 0 bytes
2023/04/05 12:32:12.132936 [TNR] Opened connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:12.139939 [HLS] Starting live stream for channel 6192 from x.x.x.x (bitrate=3200)
2023/04/05 12:32:12.743054 [HLS] ffmpeg: ch6192-dANY-ipx.x.x.x-remux: Output file #0 does not contain any stream
2023/04/05 12:32:12.803770 [HLS] Couldn't generate stream playlist for ch6192-dANY-ipx.x.x.x: Stream stopped
2023/04/05 12:32:12.803867 [HLS] Stopping transcoder session ch6192-dANY-ipx.x.x.x
2023/04/05 12:32:12.805065 [TNR] Closed connection to TVE-Spectrum for ch6192 NFL
2023/04/05 12:32:12.805154 [ERR] Probe failed for live stream after 662.116585ms and 0 bytes
I'm glad I'm not the only one, I was hesitant to post because no one else has yet either. Spectrum TVE also. I see Connection Lost (-17) on the screen. Log segment below.
2023/04/05 14:06:22.024125 [TNR] Error during live stream for ch6192 NFL: Failed to download segment 14: https://o300801-mp-lura-live.fsy.nfl.com/live/ephemeral/54AVmb0klx0KCyCYkFbJwmEle6YKX2NE/nfln-la3/3296k/eB29azo3UTr/171499/segment_171499022.ts?token=1680721566_f2b135f78a756eb3240cadf6de5a9f458c1f415c: Unknown encryption method: SAMPLE-AES
2023/04/05 14:06:22.024246 [SNR] Buffer statistics for 10.110.17.131 (Ed's Galaxy Note 9) for ch6192 NFL: buf=0% drop=0%
2023/04/05 14:06:22.041567 [HTTP] | 200 | 10.173577ms | 10.110.17.100 | GET "/log"
2023/04/05 14:06:22.042514 [HTTP] | 404 | 340.431µs | 10.110.17.131 | GET "/devices/TVE-Spectrum/status/0-3/debug"
2023/04/05 14:06:22.050701 [TNR] Closed connection to TVE-Spectrum for ch6192 NFL
2023/04/05 14:06:22.050708 [HTTP] | 200 | 4.657760043s | 10.110.17.131 | GET "/devices/TVE-Spectrum/channels/6192/stream.mpg"
Unfortunately it looks like they've added DRM so we will no longer be able to support it.
