NFL Network not even showing in scanned channels for Youtube TV TVE
Just signed up for a Youtube TV trial. When I add the YTTV source in Channels DVR, it returns 135 of 159 channels and NFL Network does not show up. Even when I manage the source and click the Scan button to see all 159 possible channels, NFL Network is not in the list to even try Re-scanning. I updated to the latest pre-release version, but still no luck. I also tried opening the NFL Network stream in a Chrome tab and then re-scanning, but no change.
Any suggestions?
NFL is not available on any TVE - feed incompatibility.
Best route is ah4c or adbtuner (easier and preferred).
I'm using Apple devices, so it doesn't look like either of those are an option for me.
You would need a client aside from the ones you are using for watching now, hooked up to an HDMI encoder box.
My personal suggestion would be a Chromecast with Google TV 4K (I would expect used prices here to be very reasonable, and dropping), and a LinkPi encoder
I would suggest using the YouTube TV app. :slightly_smiling_face:
