Updated to 2022.09.22.0024, and then the client error message on-screen changed to "Tuner not Available".
Going into the DVR settings and re-scanning the NFL Network channel "completed" the fix made in the DVR update. Provider is SlingTV. Just a heads-up in case anyone else runs into this.
This helped, thanks!
This solved my issue of not being able to open NFL Network stream using FuboTV TVE.
Steps I took that solved problem:
- Updated to latest pre-release (2022.09.23.0124)
- Re-added FuboTV as source
- Then re-authorized NFL Network by going to sources > FuboTV > select gear icon > Manage Lineup > Edit button > click gear icon for NFL Network channel > Rescan.
Thank you, everyone, after updating to 2022.09.23.0124, I had to remove the Spectrum provider and then add it back and Red Zone started working again.
I was excited because it retained all the channels I had as favorites and hidden.
I'm not able to tune into NFL network. It works fine using NFL Network | Watch Live Football Games & Events | NFL.com with my Verizon credentials.
Here are some log entries.
2022/09/25 12:36:16.236304 [TNR] Opened connection to TVE-Verizon for ch6192 NFL
2022/09/25 12:36:16.241652 [HLS] Starting live stream for channel 6192 from 127.0.0.1 (bitrate=3200)
2022/09/25 12:36:16.934269 [HLS] ffmpeg: ch6192-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2022/09/25 12:36:16.990352 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip127.0.0.1: Stream stopped
2022/09/25 12:36:16.990352 [HLS] Stopping transcoder session ch6192-dANY-ip127.0.0.1
2022/09/25 12:36:17.025095 [TNR] Closed connection to TVE-Verizon for ch6192 NFL
2022/09/25 12:36:17.025669 [HLS] Probe failed for live stream after 783.3871ms and 0 bytes
Update to prerelease:
Thanks. That fixed it. I also noticed that the NFL network doesn't appear when I set the guide filter to "Sports". Is that intentional because it is not showing a live sporting event?
My NFL Network hasn't worked for more than a week, any ideas? DirecTV
2022/10/02 07:50:57.846925 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"3e2fa676-7667-489d-9546-af2041a61a49","message":"Error in asset request"}
2022/10/02 07:50:57.921507 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:50:57.943966 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:50:57.944066 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:50:59.220579 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"c4e29c3a-fa80-4c40-a738-dd547a7a5371","message":"Error in asset request"}
2022/10/02 07:50:59.317377 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:50:59.364208 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:50:59.364313 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:50:59.995248 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"60bd53a2-b43b-49ea-be85-34633fbc6c12","message":"Error in asset request"}
2022/10/02 07:51:00.033908 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:00.060576 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:00.060674 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:51:01.312166 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"bd977bb3-5d7a-45e5-a88d-dc68ae7ee7bf","message":"Error in asset request"}
2022/10/02 07:51:01.346615 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:01.382388 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:01.382506 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:51:02.014780 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"d0f8e8f3-3520-4f03-a024-b1f5f08e3aca","message":"Error in asset request"}
2022/10/02 07:51:02.055665 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:02.085578 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:02.085684 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:51:03.313779 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"a2668208-5a2e-497d-ad18-b8b3de913693","message":"Error in asset request"}
2022/10/02 07:51:03.392923 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:03.397109 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:03.397172 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:51:04.039395 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"4f813bf1-7650-4970-b945-86ed548902df","message":"Error in asset request"}
2022/10/02 07:51:04.070912 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:04.106941 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:04.107042 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
2022/10/02 07:51:05.370758 [TVE] action=nfl_play data={"errorCode":403,"errorReason":"Forbidden","id":"f25c54f2-6008-440e-bdf3-a1ccfe67fa49","message":"Error in asset request"}
2022/10/02 07:51:05.412039 [ERR] Failed to start stream for ch6192: TVE: invalid response
2022/10/02 07:51:05.415880 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.50.233: TVE: invalid response
2022/10/02 07:51:05.415987 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.50.233
Same. I've reported it twice with logs and no response. FIOS is my TVE provider.
"Cable provider authentication failed" and "context cancelled" when trying to refresh authentication.
Same here. DTV is my TVE provider.
Thanks. I guess that’s the way.
i did a channel rescan and lost 35 channels, I'm guessing there is a bigger issue
Works fine with optimum.
2022/10/02 10:54:30.182162 [TNR] Opened connection to TVE-Cablevision for ch6192 NFL
2022/10/02 10:54:40.690926 [SNR] Buffer statistics for 192.168.1.143 (iPhone) for ch6192 NFL: buf=0% drop=0%
2022/10/02 10:54:40.693041 [TNR] Closed connection to TVE-Cablevision for ch6192 NFL
Mine said tuner not available. I had to rescan all channels and then went to the nfl network channel in the list and then rescaned just that channel. Then it started working for me.
i did a rescan and now NFLN is gone completely, this always happens when the NFL season starts
6192 NFL invalid response
and now it works
@RawisTheGameHhH Crazy. Mine works now too. (FIOS)
I feel for @tmm1 with TVE and how finicky it is. He's got some skills to keep this working.
