Here's the error message I'm getting this morning trying to activate the channel.
anvato: unexpected
@tmm1 Could you look at this at your earliest convenience?
anvato: unexpected
Getting the same error. Using fuboTV
I should have added, I'm using Youtube TV. I am able to stream through the app
Same. And after channel rescan, NFL Network is no longer there. FuboTV
I was able to log into the website as well with my credentials and I could stream both NFL Network and Redzone.
Hopefully this can be addressed asap.
Same issue here with same error, attempting RedZone auth with Spectrum.
Earlier error (~20 minutes ago) was different:
Post "https://sp.auth.adobe.com/adobe-services/authorize": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Please submit diagnostics
a65eee7f-921d-4e55-9c2c-3613a5fae26e
c07ffa63-326b-4a6e-9aa2-00039de9ccf4
043fbd1b-ddbd-45d5-aea8-11f219442d70
not sure you if you need more
f9d51e5e-70db-4ed7-af20-1a666f0e1a1c
Click and hold the check for update button
Working for me now. Thanks for the quick work.
NFL Redzone now works but NFL Network is not scanning.
Try it a few times. Everything worked fine for me on my pc server the first time. I then tested it on a server running on a Shield. I lost NFL Network, then I got it back, but it was only showing in Edit Mode. It didn't show up in the screen where you select favorite or hide it.
It took about 4 tries but eventually I got both Redzone and NFL Network back (at the same time).
0fa3cf53-35a7-42a6-b017-dd5032b5c3e3
Had issue with Redzone on Sunday. Having issue with NFL today.
a345d0cc-30f6-4f43-ac71-ce013b4a61b9
Any of you guys using the streaming only college version of Redzone and get it to work?
