So what was the source for the recordings that don't have audio?
HDHR ATSC 1.0 channel
HDHR ATSC 3.0 channel
TVE channel
Custom M3U channel
What does MediaInfo show for the video and audio tracks on one of them?
General
Complete name : \\DS1019PLUS\ChDVRhdhr\TV\Frontline\Frontline S42E07 Boeings Fatal Flaw 2024-03-12-2200.mpg
Format : MPEG-TS
File size : 1.81 GiB
Duration : 59 min 59 s
Overall bit rate mode : Variable
Overall bit rate : 4 317 kb/s
Frame rate : 59.940 FPS
Movie name : FRON 3916
Law rating : TV-PG
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 452 (0x1C4)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : 27
Duration : 59 min 58 s
Bit rate mode : Constant
Bit rate : 3 510 kb/s
Maximum bit rate : 3 718 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Active Format Description : Full frame 16:9 image
Frame rate : 59.940 (60000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.064
Stream size : 1.48 GiB (82%)
Color range : Limited
EBP_AcquisitionTime : 2024-03-13 04:59:28.317993164 UTC
EBP_Distance : 2.000
EBP_Mode : Explicit
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate : 384 kb/s
Maximum bit rate : 411 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -2 s 78 ms
Stream size : 165 MiB (9%)
Language : English
Service kind : Complete Main
Audio #2
Format : AC-3
Format settings : Dolby Surround
Codec ID : 129
Bit rate : 192 kb/s
Maximum bit rate : 214 kb/s
Channel(s) : 2 channels
Stream size : 82.4 MiB (4%)
Language : Spanish
Text #1
ID : 4193 (0x1061)-CC1
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Start time (commands) : 17 h 10 min
Stream size : 0.00 Byte (0%)
Language : English
Text #2
ID : 4193 (0x1061)-CC3
Format : EIA-608
Text #3
ID : 4193 (0x1061)-1
Format : EIA-708
Language : English
Text #4
ID : 4193 (0x1061)-2
Format : EIA-708
Text #5
ID : 4193 (0x1061)-3
Format : EIA-708
Text #6
ID : 4193 (0x1061)-4
Format : EIA-708
Text #7
ID : 4193 (0x1061)-5
Format : EIA-708
Text #8
ID : 4193 (0x1061)-6
Format : EIA-708
Menu
Format : AVC / AC-3 / AC-3
List : 4193 (0x1061) (AVC) / 4195 (0x1063) (AC-3, English) / 4196 (0x1064) (AC-3, Spanish)
Title : FRON 3916
Language : / English / Spanish
Law rating : TV-PG
Or bring up the details of the recording in the Channels DVR web UI
Options > View Details
Or open it in VLC and choose Tools > Codec Information
