No guide data after installing DVR
I broke down and purchased a QNAP NAS. I think I have it working for the DVR, but no program data is populating. I also notice that there is no longer channel/program information in the ATV app. What did I do wrong?
Is your old DVR still running? Do you want to migrate your old passes and recordings, or are you trying to setup a fresh instance?
What does the log say? Presumably you added your location and Activity said download guide data?
I removed and then re-added the channel lineup. That seems to have rectified the issue.
This looks like a bug. Setting the lineup isn’t forcing guide download, until you remove and reset it. Will fix, thanks for reporting!
Can you post your log (or email it to [email protected]). That will help me verify the bug.
This bug has been fixed in the latest version of the DVR.
