No guide data, CRC errors
Any idea how to fix this?
2018/05/13 00:42:01 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 00:42:01 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-13 6:30AM
2018/05/13 00:42:01 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-13 12:30PM
2018/05/13 00:42:02 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 00:42:03 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-13 6:30PM
2018/05/13 00:42:03 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 00:42:04 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 12:30AM
2018/05/13 00:42:05 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 00:42:05 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 6:30AM
2018/05/13 00:42:06 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 00:42:22 [IDX] Pruned 50000 expired airings from GBR-1000040-DEFAULT in 15.9881578s.
2018/05/13 11:50:49 [TNR] Opened connection to 125025D2 for ch103
2018/05/13 11:50:58 [TNR] Closed connection to 125025D2 for ch103
2018/05/13 11:51:03 [TNR] Opened connection to 125025D2 for ch101
2018/05/13 12:11:04 [TNR] Closed connection to 125025D2 for ch101
2018/05/13 13:27:27 [TNR] Opened connection to 125025D2 for ch101
2018/05/13 13:27:37 [TNR] Closed connection to 125025D2 for ch101
2018/05/13 13:33:37 [SYS] Starting Channels DVR v2018.04.05.2059 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2018/05/13 13:33:40 [ERR] could not look up CPU info: context deadline exceeded
2018/05/13 13:33:41 [HDR] Found 1 devices
2018/05/13 13:33:41 [SYS] Started HTTP Server
2018/05/13 13:34:04 [DVR] Recording engine started in E:\Multimedia\DVR
2018/05/13 13:34:04 [SYS] Bonjour service running for dvr-plexserver.local. [192.168.1.15]
2018/05/13 13:34:05 [SYS] Created database snapshot: backup-20180513.133405
2018/05/13 13:34:05 [SYS] Removing old backup backup-20180417.102629
2018/05/13 13:34:32 [IDX] Pruned 50000 expired airings from GBR-1000040-DEFAULT in 17.3492162s.
2018/05/13 13:36:54 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-13 1:30PM
2018/05/13 13:36:55 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 13:36:55 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-13 7:30PM
2018/05/13 13:36:56 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 1:30AM
2018/05/13 13:36:57 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 13:36:57 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 7:30AM
2018/05/13 13:36:58 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 13:36:58 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 1:30PM
2018/05/13 13:36:59 [DVR] Error indexing airings: IO error: GBR-1000040-DEFAULT.airings\store\030558.ldb: Data error (cyclic redundancy check).
2018/05/13 13:36:59 [DVR] Fetching guide data for 10 stations in GBR-1000040-DEFAULT @ 2018-05-14 7:30PM
The guide database has become corrupted. You can either use the installer to delete and reinstall the DVR software, or shut down the DVR and delete the “c:\programdata\channelsdvr\data\GBR-1000040-DEFAULT.airings” folder
Everything worked initially, but now I have CRC errors in DEFAULT.groups
Can I do the same with that folder? What will I lose?
Yes, I should have told you to delete both folders. They’re both used for guide data, and will be recreated automatically when guide data downloads (xxx.groups= shows, xxx.airings= episodes).
