Hello, looking for some help on Channels. I'm getting proper guide data for all of my TVE channels, but nothing for OTA. The ota guide is fine when I bring up in hdhomerun app on all OTA channels. Is there a way to refresh the guide data? I've rescanned the channels a few times, but never receive guide data. Thanks
In Sources you will see "* Manage". In that dropdown you will see "Redownload Guide". If that fails to get the guide then try "Sync Station Mappings" and as a last resort "Reload Lineup". If non of them work, "Remove Provider" and then set up again.
Good luck
Thank you, easy fix on my end. I added the tuner in the app, didn't realize I wasn't seeing all the options there in settings. It was apparently waiting for me to confirm that I wanted to use either ota guide data, or an old errored XML from a bad tuner I didn't delete. Thanks!
