Hi I can't seem to see any guide data on Shield or Android app at the moment. Is there an issue somewhere?
Cheers
Cheers
Has your Internet connection been down, perhaps?
Nah I've just restarted PC, router and shield.
Also on PC guide it only shows 2 channel's under "all". Although on the settings it says 180 channel's
Problem solved after re scanning for channels.
