Just noticed this last few days Been runnin CC4C on dedicated windows pc No issues viewing the channel No changes made to CC4C BUT now all i get is a "filler" for guide info
Any ideas??
Try doing a delete and recreate database on the guide data, wait until it finishes and check again.
Settings > Live TV & DVR > Guide Data > Maintenance > Delete and Recreate Database
If that doesn't fix it, perhaps your custom m3u has an issue (check tvc-guide-stationid
Not a CC4C issue, probably just a general guide setup problem on your end. If a rebuild of the guide doesn't work, the stations are either not mapped or mapped incorrectly...
... or your tvc-guide-stationid
is not correct in your m3u/custom text. All of that depends upon how you've set things up. No matter your approach, they should be this:
FYI, I'm using Streaming Stations in Playlist Manager for Channels for CC4C stations now so I don't have to worry about managing an m3u or doing much of anything in Channels.
Thank you all for the help this worked for me
