No guide on Firestick
Since the last update I don't have any data in the guide just the channel id.
in settings under guide database then maintenance - click on re-download entire guide. See if that helps.
I have to subscribe to get the guide now?
yes. if u want dvr functionality and on the dvr server is where all the controls are for guide database. that has never changed.
I assume by your statement, however, that you are using the standalone version of Channels that is for HDHR live view only, and NOT the normal version that 99% of users here assume you are asking about.
If so, you need to indicate that in your posts.
I think, though i have never used that version, the guide info would come from the HDHR app itself?? Have you opened it up and see if it has guide info? Otherwise, i have no idea how Channels does the standalone LIVE TV only app.
