The previous channel (recall, flashback, whatever) funcitonality has been broken on my ATV since Channels 2.0.
System has been restarted, same behavior.
Help!
Help!
Which button are you double-clicking?
In 2.0 they changed the channel recall double-click button from the touchpad to the play/pause button.
Same problem here. Try to double-click the play/pause button (tried fast and slow) and it pauses everytime. Anyone from Channels care to comment please?
Are you clicking the dedicated play/pause button near the bottom of the Siri remote?
For no explainable reason it just started working. Thanks anyway for your quick reply tmm1
