No record option in quick guide (HDFX-4K)
Hello,
I recently swapped a HDHomerun Quattro for HDFX-4K. I don't see the record option in the quick guide. Also, scheduled shows aren't been recorded. TV Everywhere source is working fine with record option. Did I miss a step when I made the swap to HDFX-4K?
Have you assigned guide data to the Flex in the DVR web UI since adding it to your network? Without guide data assigned to the device, the DVR will not use the device for recording.
I went through the basic setup process to add the new source but it's still reading the old tuner address in the "bonjour" option.
That's not the tuner's IP, but rather your DVR server's address. The tuner's IP address will be listed under it's entry in the source list.
Yes that's right, thanks for your help.
I found the fix for this issue. Channels DVR app must be deleted from your device. Then re-download Channels DVR app. Now I have recording available.
