Used to work like a charm, but now I get “Error: tuner not found” when manually adding a remote tuner. Is remoteipaddress:8089 working for anybody out of the house? (Works on iOS)
Been using my on ATT network for past 2 hours, but through both the IOS app and WebGui, but they were already configured.
Just removed and re added the tuner’s manually without a problem. You probably had this, but you have to have the :8089 at the end, or it will respond tuner not found.
Does it work for you also on ATV or just on the iOS app? Thanks!
This is a known issue
