No Sound - Locast
Hello all. New to Channels and Locast. So, I downloaded Channels, set it up and configured for Locast. Works fine except for 52.2 in Philadelphia NHKWorld. When I go to the channel it freezes and will not play. Back out repeat...same thing. After a few attempts it will stream but with no sound. If I choose to record the video records fine but again no audio. Video and audio on Locast site but not through channels as I have these problems. Any advice?
What happens when you try streaming 52.2 directly from the Locast App (assuming you can install the Locast App)?
