"No space left on device" errors on Pi4
8a78f11a-e5f7-4856-a7f3-d9c9b73ef8f4 submitted. Wondering if something is writing to the USB stick i have attached for ssh? I don't have (shell) access at the moment to the pi, but will look later on.
My USB drive is only 18% full - should have included that first :slight_smile:
2020/12/10 09:53:39.722575 [ERR] Guide database failure: got err persisting snapshot: error persisting segment: write USA-OTA06468.airings/store/000000001017.zap: no space left on device
Use the Guide Maintenance > Delete and Recreate option.
A fix is coming today
Thanks.
Please update to latest pre-release
I get a similar error on v2021.02.04.1931
2021/03/02 16:16:46.517550 [ERR] Guide database failure: merging err: merging failed: write GBR-1000051-DEFAULT.airings/store/00000000042f.zap: no space left on device
Please submit diagnostics so we can take a look at what's going on.
cb67ed2d-e2a8-4384-9fe8-4c8894d2ddc6
Also sent by support email
Your system is running out of disk space due to all the docker stuff running. Docker is not a supported feature of the Pi image, so you're on your own if you decide to run Plex and other stuff on the same device.
You could SSH in and run this to see where all the space went:
du -cahd1 /mnt/data
Ah ok, I wasn't aware. I'll have a cleanout - cheers! :grinning:
