I sometimes use Channels via a router+VPN setup, which means my SiliconDust device can’t be found by normal bonjour/broadcast mechanism.
Not usually a problem, because I just select to Add Tuner Manually on the Settings page that appears by default when nothing is found on the network.
However, I’ve noticed this isn’t working now. Not sure when since, but I’m using Channels 3.1 and tvOS 11.0 (release version), but while the Settings page comes up, but I can swipe down (Settings / Navigation bar at top disappears), I don’t actually have any highlighting of the menu items (i.e. Scan network for tuners, Add tuner manually, Login to Remote DVR, etc).
Has something broken in a recent release to stop this page being navigable when it comes up by default in a No Tuners Detected situation?
