How do you remove a Tuner? There's no option here.
You can't you just have to remove the Provider.
The provider was removed, so once you add a tuner, its there forever? Wow, I honestly didnt see that one coming. I guess experimentation ith a bunch of devices that can never be removed is not a good idea then.
Is the tuner still on your network? If not, you can restart the dvr software
As long as HDHR tuners are on your local network advertising their presence, Channels DVR will see them and they'll appear as a source device.
If you power off or remove an HDHR tuner from your local network, it will disappear from Channels DVR after a restart.
If you added an HDHR tuner by specifying its IP address, there is a curl command to remove it.
You can hide HDHR tuners from Channels DVR by putting them on a different subnet or by running Channels DVR in a container that uses a bridge network instead of the host network.
OK, I rebooted the server channels is running on, because there's no way that I find to restart the Channels from the Web Server page (this would be a nice feature so I don't have to crush a Ubuntu server every time I want to restart Channels). It did go away. I unplugged it (the HDHR) three days ago, and since there hasn't been any preleases in the last few days, ChannelsDVR never got restarted. I was going crazy trying to figure this out.
Thanks!!!
True, Would be nice to have that.
You can restart using
curl -XPUT http://127.0.0.1:8089/updater/force/restart
systemctl restart channels-dvr
