Not able to connect to my.channelsdvr.net
I set up a new server on a Mini PC. I cannot connect to my.channnelsdvr.net on the same computer or another computer on my network. However, I can connect when I am on cellular.
I didn't have this problem when the server was on my iMac. I can watch shows using Channels while on my network and outside it. I also have Remote Sharing set to Auto.
Very odd I can't connect using that URL on the same Mini PC. (To connect, I click the Channels Server icon on the task bar).
Any ideas?
Did you get a new router? If so it probably doesn’t support hairpin NAT. You will have to use the actual ip:8089 of the server to get to the web ui while on your home lan.
Very strange. I just went back to check and Auto is saying it could not establish a remote connection. I'll set up a port forward. Thanks!
