All of a sudden I'm getting the Spanish audio only or in some cases the descriptive audio for the ATSC3.0 channels. The audio option only lists Spanish for them, and the channels play back is choppy.
Are you able to check the live source signal from HDHomerun (presumably what you're using for a tuner)? My one ATSC3.0 channel here has gone through periods of time where the main audio channel is either completely missing or broken.
I went into the HDHR app on my TV and changed the audio to SAP and back and that seemed to fix it in Channels. I'm not sure what's going on though, seems like I should be able to make those changes within Channels too.
It has gone back to only listing "Spanish" for the Audio Language. When I use the HDHR app I am able to cycle through all of the options. On the non-3.0 channels everything is fine. I'm using the AppleTV.
