Not picking up Comskip.ini file
I have a Comskip.ini file defined here, /Users/dvruser/Library/Application Support/ChannelsDVR/data/comskip.ini
But in the Comskip.log file it just references, Comskip.ini. And none of my custom settings have been applied.
Generated using donator Comskip 0.82.005
Time at start of run:
Thu Feb  6 19:07:57 2020
Mpeg:	/Volumes/ChannelsDVR/recordings/TV/Little House on the Prairie/Little House on the Prairie S03E17 1977-02-21 To Live With Fear 2020-02-06-1800.mpg
Exe	comskip.exe
Logo:	/Volumes/ChannelsDVR/recordings/Logs/comskip/10655/video.logo.txt
Ini:	comskip.ini
Any ideas on how to fix?
The data directory is where comskip runs, so comskip.ini refers to the local config in that directory.
Thanks. Figured it out. I was using # instead of ; for comments.
