Two days ago Channels DVR appears to have stopped receiving and recording shows. During the recording times I saw red dots displayed in the web UI, but instead all shows remained "queued" long after they were over, with only the first missed show listed as "failed".
First failed show:
2020/01/13 18:00:00.007425 [DVR] Starting job 1578967200-1 The Rachel Maddow Show on ch=[6050]
2020/01/13 18:00:00.007558 [DVR] Waiting 5h34m59.992455748s until next job 1578987300-2 The Late Show With Stephen Colbert
2020/01/13 18:00:00.008152 [TVE] action=auth mvpd=Comcast_SSO requestor=msnbc
2020/01/13 20:25:57.673439 [CACHE] Deleted cache for file 475 (19.1MB). Last access was 2019-12-30 16:32:30 -0800 PST.
2020/01/13 23:35:00.009933 [DVR] Marking expired job 1578967200-1 The Rachel Maddow Show
Then nothing but guide updates in the log, even though there were several shows queued.
After noticing the problem this morning, I also discovered I could not watch live OTA or TVE through Channels DVR. I could watch the same live TV shows directly on my PC via the HDHR app and Xfinity Stream.
2020/01/15 06:50:48.350886 [HLS] Stopping transcoder session ch2.1-dANY-ip192.168.0.175
2020/01/15 06:50:48.385222 [HLS] Couldn't generate stream playlist for ch2.1-dANY-ip192.168.0.175: Stream stopped
2020/01/15 06:54:29.176920 [HLS] Stopping transcoder session ch6050-dANY-ip192.168.0.175
2020/01/15 06:54:29.244009 [HLS] Couldn't generate stream playlist for ch6050-dANY-ip192.168.0.175: Stream stopped
Those same channels were received OK in the HDHR app and Xfinity Stream. My Synology NAS also seemed to be running OK.
I could see no way to do a software restart of Channels DVR, so I forced an update from 2020.01.01.0239 (uptime 14 days) to 2020.01.15.0443.
That restarted Channels DVR, and I see in the log it then marked all expired recordings, which are now listed as "failed" in the web UI too, and everything seems to have started working again. Live TV can be received, and recordings will probably work.
