On my Fire Stick 4k I was able to in DVR beta and now I can see all my recordings. But on my main tv (a Fire TV) Fire OS 5.2.8.1 ; Fire TV Home Version 6242057.1 I can't see all the recordings. When I try to install DVR Beta i get parsing error. How do I see all the recordings listed in TVEverywhere on my Fire TVs?
You have two DVR servers installed, one on your PC and one on your QNAP. The clients must be connected to different servers.
That makes since. The recordings on the QNAP don't show up on on The Fire TV. N00b here , what do I do to point them all to the QNAP? And How to remove the PC version.
On the PC run the installer from our website and select uninstall
Then the FireTV would connect automatically. Or you can click Settings > Channels DVR Logo > At Home and enter the IP of your QNAP
Can I consolidate the recording shows from PC to the ones on the QNAP?
You could move them into Imports on the QNAP
I can't figure out how to uninstall Channel DVR on my PC. I can't find the install to run off the website?
