At some point, at least with some channels, your TVE login will “time out” and require you to log back in. I have only been able to discover when this happens by noticing that a program didn’t record and by that point I will usually have missed several recordings on the channel.
Instead of having to actively monitor the success of scheduled recordings, is there any way to have Channels notify the user when its attempt to record a channel fails for an authorization issue, giving you the opportunity to fix the problem before more recordings are missed?
Thanks for any help.
