Notify Icon in Android doesn't work
Using the Notify API command for Android the Icon part of it doesn't work - you just get the "!" sign regardless of what you set payload.icon to. I know it works OK in iOS from when I was testing that.
I first posted about this a while back and wondered if there is any update on it?
