Nucleus HTPC
The older Surface Pro, including mine, were x64. The latest models are Snapdragon.
@jtanderson I tried testing adding touch gestures to it locally and it broke a few mouse click events. I will set up a development repo and work on adding touch screen support where I don’t break anything in the main repo. Once I get that working correctly, I’ll merge it to the main repo
Don't rush into anything on my account. I would, at most, be a casual user.
I may have missed this. Can I watch a recording as it is being recorded?
I did not attempt to view as recording. If Channels DVR allows you to stream it while it is recording you can, but I do not have a large enough buffer built into Nucleus to do time shifting on live tv. I will add that in a future release, but as of now, live tv time shifting is not supported.
What about picking the recording (being recorded) to watch, instead of the live channel being recorded?
Channels DVR allows that and so does DVRDesk.
Yes, what chDVRuser said. I am not looking to time shift live tv, only recordings.
If not this is fine.
Your program work great, thank you for sharing.
I'll look into the endpoints being used. Thanks
