Nucleus HTPC
I am working on a failed tune error overlay to hopefully let users know when a tune failed instead of staying in limbo. It might take awhile. Hopefully not though..
1.2.3 Released
Added a failure to tune screen with a "Return to Guide" button.
Increased loading timeout from 5 seconds to 8.
Thes 1.2.3 release has an increased timeout and a new failed tune overlay. Hopefully 8 seconds is enough to tune your channels.
failure overlay works great.
figured out my problem however. After some google foo, In my market, NBC 10 is actually on 15.1 not 10. 10 is out of providence, not Boston. they advertise as 10 because that's where it is on cable. Dumb.
Im not sure why a bunch of them were failing earler, but it seems to be fine now. Probobly slow/sleeping channels server.
Awesome. Thanks for letting me know. The failures could have been due to the original 5 second tuner timeout being too aggressive. Hopefully 8 works better.
Thank you Bobby,
Working well
Thank you I just tested it's fixed. I really appreciate it.
Hi Bobbie,
Thank you for implementing Collections. My wife noticed that the right click menu is missing in Collections. Also, Delete is missing from the menues.
Thank you for all you do
I think we need about +10 more second for a station to tune before it is a failure to give a lot of other backend processes time to finish first. Think of something like a FastChannels custom station where it has to go the website, load it up, find an active stream, and then parse it. And now imagine Channels processing on top of that!
I'll increase it for the next release.
I've just about got the right click menu finished. It will be finished in next release along with sorting.
1.2.4 Released
@Morris_Altman Collections sorting and right click edits added.
@babsonnexus Tuning timeout increased to 15 seconds. If you need more, I can do that no problem. I think the DVR times them out around 20 seconds and my timer starts 2-3 seconds after theirs.
Replaced all drop-down menus with remote control friendly overlay menus.
Added more remote control key mapping.
I did not start on the light theme. That is going to take more time than I have for the remainder of the week. Hopefully next week.
Thanks and enjoy.
Edit: Videos sorting added and all sorting has been unified
Thank you Bobby,
In TV Show Collections, empty folders display. Also, the sort direction is not remembered when I leave and return.
Im not seeing my empty show folders in collections. Is there anything special about the shows you are seeing folders for?
Try the 1.2.5 update and see if that fixed it.
Unfortunately it has not fixed the empty folders showing. I'm wondering if it's something about my environment. My Channels DVR server runs on Windows 11 and the storage is managed by Storage Spaces. My desktop that's running Nucleus HTPC is also Windows 11. The folders that are empty had recordings in some and stream links is others. It doesn't seem to be related to the file type.
If you hit the F key, it exits full screen mode and is windowed. It still maintains a 720px ratio. Switching back to full screen and again to windowed will return the 720 screen centered.
Windowed, yes, but no way to resize the window in the usual way.
That is expected behavior. I have a lot of rendering logic going on to make the overlays and buttons work well for the screen and remote controls. If you want it to be a different size, use the windows snap feature.
The environment should not matter. I am using the Channels API responses to determine if a folder is empty or not. I am assuming you mean to the Collections front page, correct? If you would, provide me with the json response from your dvr for the /api/v1/collections/{ID}/content endpoint, where it {ID} is the ID of the collections that show when empty. For example, http://127.0.0.1:8089/api/v1/collections/8/content is one of mine that is empty and not showing. On the browser window click the pretty-print box and click Ctrl A to highlight the response and copy and past me the json.
When I select collections, I see the list of movie and TV show collections. When I select the TV show collection, I see the shows and shows that have empty folders show up.
This is the URL I created using your example:
http://192.168.2.23:8089/api/v1/collections/6/content
One of the empty folders is Nova
The result:
[{"id":"11078228","name":"Air Warriors","summary":"\"Air Warrriors\" puts the spotlight on some of the airplanes that have been used by American forces in combat battles through the years. The program profiles the dedicated pilots and other team members who fly and maintain the aircraft. Rarely seen combat footage and pilots' stories help bring to life the journeys that have been taken by the flying machines, which include a plane-chopper hybrid that saves lives and an attack helicopter that is called the Black Death by America's enemies.","image_url":"https://tmsimg.fancybits.co/assets/p11078228_b_h9_al.jpg?w=720\u0026h=540","release_year":2014,"release_date":"2014-10-19","genres":["Documentary","Military","History"],"categories":["Show","Series"],"cast":["Beau Weaver"],"number_unwatched":0,"favorited":false,"last_watched_at":1685369072067,"last_recorded_at":1685322000010,"created_at":1652054400000,"updated_at":1783082104803},{"id":"8811659","name":"Air Disasters","summary":"Statistically, traveling by airplane is safer than driving and other forms of transportation, but when something goes wrong during a flight, it can be catastrophic with potentially hundreds of lives at stake. This series examines some of the world's worst air disasters, using official reports, transcripts and interviews with people involved to tell the stories of midair mishaps and discover what went wrong in each case. Episodes include a discussion of how the weather affects flights -- including stories of aviation disasters and near-misses -- and a New Year's Eve flight that fell from the sky into the Florida Everglades.","image_url":"https://tmsimg.fancybits.co/assets/p8811659_b_h9_ag.jpg?w=720\u0026h=540","release_year":2011,"release_date":"2011-05-15","genres":["Documentary","Aviation"],"categories":["Show","Series"],"cast":["Bill Ratner"],"episode_count":207,"number_unwatched":207,"favorited":false,"last_watched_at":1769449768056,"last_recorded_at":1777025528822,"created_at":1646010000000,"updated_at":1784849151337},{"id":"184159","name":"NOVA","summary":"This long-running, award-winning documentary series focuses on science, its many applications, speculation, history and researchers. Inspired by the BBC documentary program \"Horizons, \" the U.S. series frequently features interviews with scientists directly involved in the topic at hand, and sometimes even boasts footage of a particular discovery.","image_url":"https://tmsimg.fancybits.co/assets/p184159_b_h9_af.jpg?w=720\u0026h=540","release_year":1974,"release_date":"1974-03-03","genres":["Science","Nature","Anthology"],"categories":["Show","Series"],"cast":["Craig Sechler"],"number_unwatched":0,"favorited":false,"last_watched_at":1777654156512,"last_recorded_at":1777510807675,"created_at":1631754003000,"updated_at":1783082102904},{"id":"9669520","name":"Miracles of Nature","summary":"Nature's attractions around the world.","image_url":"https://tmsimg.fancybits.co/assets/p9669520_b_h9_ag.jpg?w=360\u0026h=270","release_year":2012,"release_date":"2012-12-16","genres":["Documentary"],"categories":["Show","Series"],"labels":["Morris"],"number_unwatched":0,"favorited":false,"last_watched_at":1773211790855,"last_recorded_at":1649498400589,"created_at":1641492000000,"updated_at":1783082105674},{"id":"20955415","name":"Married to Real Estate","summary":"Real estate broker and designer Egypt Sherrod, alongside her husband, builder Mike Jackson, juggle their busy professional and personal lives while helping clients land their perfect home in a dream neighborhood.","image_url":"https://tmsimg.fancybits.co/assets/p20955415_b_h9_av.jpg?w=720\u0026h=540","release_year":2021,"release_date":"2021-12-18","genres":["Home improvement","House/garden"],"categories":["Show","Series"],"cast":["Egypt Sherrod","Mike Jackson"],"number_unwatched":0,"favorited":false,"last_watched_at":1748558309932,"last_recorded_at":1748480400661,"created_at":1641526200000,"updated_at":1783082104229},{"id":"505353","name":"The FBI Files","summary":"Behind the scenes of major case investigations.","image_url":"https://tmsimg.fancybits.co/assets/p505353_b_h9_al.jpg?w=360\u0026h=270","release_year":1998,"release_date":"1998-09-29","genres":["Documentary","Crime"],"categories":["Show","Series"],"cast":["James Kallstrom"],"episode_count":49,"number_unwatched":49,"favorited":false,"last_watched_at":1768271014200,"last_recorded_at":1665367201690,"created_at":1633597204000,"updated_at":1784849162370},{"id":"26324962","name":"Extreme Airport Africa","summary":"Exploring high-octane aviation stories across Southern Africa.","image_url":"https://tmsimg.fancybits.co/assets/p26324962_b_h9_ab.jpg?w=720\u0026h=540","release_year":2024,"release_date":"2024-01-07","genres":["Documentary"],"categories":["Show","Series"],"number_unwatched":0,"favorited":false,"last_watched_at":1754691096172,"last_recorded_at":1742173200078,"created_at":1709175601000,"updated_at":1783082104320},{"id":"22803304","name":"America's National Parks","summary":"National parks reveal the diversity, wonder and beauty of America, from the lush valley floors of Yosemite to the constantly erupting volcanoes of Hawaii.","image_url":"https://tmsimg.fancybits.co/assets/p22803304_b_h9_ap.jpg?w=720\u0026h=540","release_year":2022,"release_date":"2022-08-29","genres":["Documentary","Nature","Animals"],"categories":["Show","Series"],"cast":["Garth Brooks"],"number_unwatched":0,"favorited":false,"last_watched_at":1760234199462,"last_recorded_at":1750449600592,"created_at":1686002401000,"updated_at":1783082104185},{"id":"12617092","name":"Maine Cabin Masters","summary":"There's no shortage of work for Maine-based builder Chase Morrill, whose specialty is renovating rustic cabins and camps all over the Pine Tree State. Working alongside his sister, brother-in-law and best friend, Morrill contracts with clients to save and transform rundown cabins buried deep in Maine's remote woods. From century-old cottages to lakeside retreats in need of some major repairs, Chase and his team give these dilapidated properties the revivals they have needed for decades.","image_url":"https://tmsimg.fancybits.co/assets/p12617092_b_h9_ax.jpg?w=720\u0026h=540","release_year":2017,"release_date":"2017-02-23","genres":["Reality","Home improvement","House/garden","How-to"],"categories":["Show","Series"],"cast":["Chase Morrill","Ashley Morrill","Ryan Eldridge","Matthew Dix","Jared Baker"],"number_unwatched":0,"favorited":false,"last_watched_at":1769554349836,"last_recorded_at":1782814331770,"created_at":1631063066000,"updated_at":1783204061729},{"id":"185481","name":"Nature","summary":"Consistently stunning documentaries transport viewers to far-flung locations ranging from the torrid African plains to the chilly splendors of icy Antarctica. The show's primary focus is on animals and ecosystems around the world. A comic book based on the show, meant to be used an as educational tool for kids, was briefly distributed to museums and schools at no cost in the mid-2000s.","image_url":"https://tmsimg.fancybits.co/assets/p30915708_b_h9_ab.jpg?w=720\u0026h=540","release_year":1982,"release_date":"1982-10-10","genres":["Anthology","Nature"],"categories":["Show","Series"],"cast":["F. Murray Abraham","Chris Morgan","George Page","David Attenborough","Julia Roberts","Lynn Sherr"],"episode_count":6,"number_unwatched":6,"favorited":false,"last_watched_at":1784753144948,"last_recorded_at":1776902400602,"created_at":1630158970000,"updated_at":1784849160530},{"id":"19223615","name":"How Did They Build That?","summary":"An exploration of how some of the world's biggest man-made structures were built.","image_url":"https://tmsimg.fancybits.co/assets/p19223615_b_h9_aa.jpg?w=720\u0026h=540","release_year":2021,"release_date":"2021-01-03","genres":["How-to"],"categories":["Show","Series"],"cast":["Scott Rummel"],"number_unwatched":0,"favorited":false,"last_watched_at":1760731863653,"last_recorded_at":1759712401300,"created_at":1657497601000,"updated_at":1783082104088},{"id":"184224","name":"60 Minutes","summary":"The oldest and most-watched newsmagazine on television gets the real story on America's most prevalent issues. CBS News correspondents contribute segments to each hourlong episode. Topics range from hard news coverage to politics, lifestyle, pop culture, business, health, and science. The correspondents and contributors include Sharyn Alfonsi, Anderson Cooper, Steve Kroft, Lara Logan, Norah O'Donnell, Scott Pelley, Charlie Rose, Lesley Stahl, Jon Wertheim, Oprah Winfrey and Bill Whitaker.","image_url":"https://tmsimg.fancybits.co/assets/p31308310_b_h9_ae.jpg?w=720\u0026h=540","release_year":1968,"release_date":"1968-09-24","genres":["Newsmagazine"],"categories":["Show","Series"],"cast":["Sharyn Alfonsi","Anderson Cooper","Lara Logan","Norah O'Donnell","Scott Pelley","Lesley Stahl","Jon Wertheim","Bill Whitaker","John Dickerson"],"number_unwatched":0,"favorited":false,"last_watched_at":1782756783058,"last_recorded_at":1784502000434,"created_at":1630278001000,"updated_at":1784676928035},{"id":"18864180","name":"Ice Airport Alaska","summary":"A chronicle of the daily challenges of the airport staff who manage to keep the facility open, freight flowing and passengers flying all despite weather that regularly dips to -36 degrees and wind speeds that typically exceed 100 mph.","image_url":"https://tmsimg.fancybits.co/assets/p18864180_b_h9_ag.jpg?w=720\u0026h=540","release_year":2020,"release_date":"2020-10-26","genres":["Documentary","Aviation"],"categories":["Show","Series"],"cast":["Kerry Shale"],"episode_count":44,"number_unwatched":44,"favorited":false,"last_watched_at":1770404030463,"last_recorded_at":1774138995343,"created_at":1674439200000,"updated_at":1784849161044},{"id":"20598195","name":"History's Greatest Escapes with Morgan Freeman","summary":"Interviews and re-creations bring some of history's most daring jailbreaks to life, detailing every step of the way, including the inmates' meticulous plans and the manhunts that followed; Academy Award-winning actor Morgan Freeman, who starred in \"Shawshank Redemption,\" a film focusing on the exploits of a group of inmates inside the fictional Shawshank State Penitentiary, hosts and executive produces the series; conversations with some of the prisoners, their families, their cellmates, guards and prison employees are used to round out the potrayals of famous escapes from Alcatraz, Dannemora, Pittsburgh State Penitentiary and other locations.","image_url":"https://tmsimg.fancybits.co/assets/p27610698_b_h9_aa.jpg?w=720\u0026h=540","release_year":2021,"release_date":"2021-11-09","genres":["Documentary","Crime"],"categories":["Show","Series"],"cast":["Morgan Freeman"],"number_unwatched":0,"favorited":false,"last_watched_at":1768586756472,"last_recorded_at":1761764400095,"created_at":1721696402000,"updated_at":1783082104044},{"id":"15113995","name":"Tom Clancy's Jack Ryan","summary":"Author Tom Clancy introduced the character of Jack Ryan in a series of books before Ryan headed to the big screen in several films. Now the former U.S. Marine is featured in an episodic series for the first time, with John Krasinski portraying Ryan in this Amazon original thriller that centers on Ryan as an up-and-coming CIA analyst. He is thrust into a dangerous field assignment for the first time and uncovers a pattern in terrorist communication. That launches him into the middle of a dangerous gambit with a new breed of terrorism that threatens destruction on a global scale.","image_url":"https://tmsimg.fancybits.co/assets/p24722000_b_h9_aa.jpg?w=360\u0026h=270","release_year":2018,"release_date":"2018-08-31","genres":["Thriller"],"categories":["Show","Series"],"cast":["John Krasinski","Wendell Pierce","Noomi Rapace","Michael Kelly"],"number_unwatched":0,"favorited":false,"last_recorded_at":1769475136586,"created_at":1769476262000,"updated_at":1783082103723},{"id":"186106","name":"Cold Case Files","summary":"\"Cold Case Files,\" one of A\u0026E Network's most popular and successful series of all time, chronicles the re-examination of long-unsolved crimes and the journeys of law enforcement personnel who reopened them. With the use of forensic advances and new evidence, police and detectives attempt to crack the cases and clarify unanswered questions. Each story is brought to life through cinematic dramatizations and first-person storytelling from the detectives and loved ones who lived through the harrowing experiences. Original episodes, which date back to 1999 and span nearly 10 years, are hosted by Bill Kurtis.","image_url":"https://tmsimg.fancybits.co/assets/p12471643_b_h9_ac.jpg?w=360\u0026h=270","release_year":1999,"release_date":"1999-01-01","genres":["Documentary","Crime","Law"],"categories":["Show","Series"],"cast":["Bill Kurtis"],"episode_count":2,"number_unwatched":2,"favorited":false,"last_recorded_at":1783024407016,"created_at":1769475874000,"updated_at":1784157956944},{"id":"184927","name":"Cold Case","summary":"The Philadelphia homicide squad's lone female detective finds her calling when she is assigned cases that have never been solved. Detective Lilly Rush combines her natural instincts with the updated technology available today to bring about justice for all the victims she can.","image_url":"https://tmsimg.fancybits.co/assets/p7893205_b_h9_aa.jpg?w=360\u0026h=270","release_year":2003,"release_date":"2003-09-28","genres":["Crime drama","Mystery"],"categories":["Show","Series"],"cast":["Kathryn Morris","Danny Pino","John Finn","Jeremy Ratchford","Thom Barry","Tracie Thoms"],"episode_count":156,"number_unwatched":156,"favorited":false,"last_recorded_at":1769475667569,"created_at":1769475793000,"updated_at":1784849161484},{"id":"203985","name":"Air Crash Investigation","summary":"Catastrophic incidents in aviation history are meticulously re-enacted, providing insight into what went wrong and if the crashes and near-disasters could have been prevented; accounts from survivors combine with cockpit recordings and computer images to weave the gripping tales and expert testimony reveals the hows and whys behind the events, some of which have resulted in important changes to aviation safety and regulations.","image_url":"https://tmsimg.fancybits.co/assets/p29033716_b_h9_ad.jpg?w=360\u0026h=270","release_year":2003,"release_date":"2003-08-06","genres":["Documentary","Aviation","History"],"categories":["Show","Series"],"episode_count":3,"number_unwatched":3,"favorited":false,"last_recorded_at":1784542329044,"created_at":1769475691000,"updated_at":1784849150703},{"id":"13748348","name":"Cold Case Files","summary":"\"Cold Case Files,\" one of A\u0026E Network's most popular and successful series of all time, chronicles the re-examination of long-unsolved crimes and the journeys of law enforcement personnel who reopened them. With the use of forensic advances and new evidence, police and detectives attempt to crack the cases and clarify unanswered questions. Each story is brought to life through cinematic dramatizations and first-person storytelling from the detectives and loved ones who lived through the harrowing experiences. Bill Kurtis narrates.","image_url":"https://tmsimg.fancybits.co/assets/p20450113_b_h9_ab.jpg?w=720\u0026h=540","release_year":2017,"release_date":"2017-02-27","genres":["Documentary","Crime","Law"],"categories":["Show","Series"],"cast":["Bill Kurtis"],"number_unwatched":0,"favorited":false,"last_watched_at":1644086750693,"last_recorded_at":1774138991724,"created_at":1644026402000,"updated_at":1783082103463},{"id":"439881","name":"Medical Detectives","summary":"Eagle-eyed technical experts prove there is no such thing as a perfect crime as they assemble the pieces every criminal leaves behind. Dramatic crime re-creations and, sometimes, part of the investigations are a staple of the series. Some of the re-creations include alternate versions of the crimes, which are disproved by science. The show's episodes follow each case from the initial investigation until it reaches its legal resolution.","image_url":"https://tmsimg.fancybits.co/assets/p439881_b_h9_bc.jpg?w=360\u0026h=270","release_year":1996,"release_date":"1996-04-21","genres":["Documentary","Crime","Medical"],"categories":["Show","Series"],"cast":["Peter Thomas"],"episode_count":400,"number_unwatched":400,"favorited":false,"last_watched_at":1639630352030,"last_recorded_at":1783024408059,"created_at":1630247732000,"updated_at":1784849151134},{"id":"17847753","name":"Forensic Files II","summary":"Real-life investigations feature experts drawing on forensic science to solve baffling crimes and other mysteries.","image_url":"https://tmsimg.fancybits.co/assets/p17847753_b_h9_ag.jpg?w=720\u0026h=540","release_year":2020,"release_date":"2020-02-23","genres":["Crime","Science"],"categories":["Show","Series"],"number_unwatched":0,"favorited":false,"last_watched_at":1643483648427,"last_recorded_at":1769475342614,"created_at":1631383203000,"updated_at":1783082103664},{"id":"pluto/62fad007362313001aa92dca","name":"60 Minutes","image_url":"https://images.pluto.tv/series/62fad007362313001aa92dca/tile_1762414464261.jpg?fill=blur\u0026fit=fill\u0026fm=jpg\u0026h=900\u0026q=75\u0026w=900","number_unwatched":0,"favorited":false,"last_watched_at":1770040023386,"last_recorded_at":1770004800291,"created_at":1770004800000,"updated_at":1783082103595},{"id":"184930","name":"NCIS","summary":"Naval Criminal Investigative Service Special Agent Leroy Jethro Gibbs leads a group of colorful personalities in investigating crimes -- ranging from murder and espionage to terrorism -- that have evidence connected to Navy and Marine Corps personnel. The team includes witty ex-homicide detective Anthony DiNozzo, quirky forensics specialist Abby Sciuto, and the brilliant -- if insecure -- Timothy McGee. Dr. Donald \"Ducky\" Mallard brings his vast experience in forensics into play to help solve cases.","image_url":"https://tmsimg.fancybits.co/assets/p30698219_b_h9_ab.jpg?w=360\u0026h=270","release_year":2003,"release_date":"2003-09-23","genres":["Crime drama","Action","Adventure","Mystery"],"categories":["Show","Series"],"cast":["Sean Murray","Wilmer Valderrama","Brian Dietzen","Diona Reasonover","Katrina Law","Rocky Carroll","Gary Cole"],"number_unwatched":0,"favorited":false,"last_recorded_at":1773223933274,"created_at":1769135603000,"updated_at":1783082103557},{"id":"184111","name":"This Old House","summary":"Award-winning pros renovate homes with quality craftsmanship and the latest technology.","image_url":"https://tmsimg.fancybits.co/assets/p30660848_b_h9_aa.jpg?w=360\u0026h=270","release_year":1979,"release_date":"1979-01-01","genres":["Home improvement","How-to","House/garden"],"categories":["Show","Series"],"cast":["Kevin O'Connor","Richard Trethewey","Tom Silva","Jenn Nawada"],"number_unwatched":0,"favorited":false,"last_watched_at":1784480033969,"last_recorded_at":1784408401005,"created_at":1777725000000,"updated_at":1784480198703},{"id":"186265","name":"Ask This Old House","summary":"Created by viewer demand, the series is a spinoff of \"This Old House\" and answers specific remodeling questions that viewers send in. The cast includes host Kevin O'Connor, general contractor Tom Silva, heating/plumbing master Richard Trethewey and landscaper Roger Cook, who spend the hour focusing on various topics for the do-it-yourself homeowner.","image_url":"https://tmsimg.fancybits.co/assets/p30660883_b_h9_aa.jpg?w=360\u0026h=270","release_year":2002,"release_date":"2002-10-12","genres":["House/garden","How-to","Home improvement"],"categories":["Show","Series"],"cast":["Kevin O'Connor","Tom Silva","Richard Trethewey","Roger Cook","Jenn Nawada","Mark McCullough","Mauro Henrique","Nathan Gilbert"],"number_unwatched":0,"favorited":false,"last_watched_at":1784481135495,"last_recorded_at":1784410200080,"created_at":1777757400000,"updated_at":1784481220475},{"id":"32646212","name":"Life on Earth: Attenborough's Greatest Adventure","summary":"The story behind David Attenborough's wildlife documentary series \"Life on Earth,\" which changed his life forever.","image_url":"https://tmsimg.fancybits.co/assets/p32646212_b_h9_aa.jpg?w=720\u0026h=540","release_year":2026,"release_date":"2026-05-06","genres":["Special","Documentary"],"categories":["Show","Special"],"cast":["David Attenborough"],"number_unwatched":0,"favorited":false,"last_watched_at":1778122295931,"last_recorded_at":1778112000506,"created_at":1778112000000,"updated_at":1783082102858},{"id":"31531740","name":"Shared Planet","summary":"Untold stories of people and animals flourishing together, making space for nature and choosing collaboration over control.","image_url":"https://tmsimg.fancybits.co/assets/p31531763_b_h9_aa.jpg?w=360\u0026h=270","release_year":2025,"release_date":"2025-11-01","genres":["Documentary"],"categories":["Show","Series"],"number_unwatched":0,"favorited":false,"last_watched_at":1778261662937,"last_recorded_at":1778806800559,"created_at":1778202000000,"updated_at":1783082102839},{"id":"15198428","name":"The Himalaya Connection","summary":"The effects of Indian and Asian tectonic plates crashing below the Himalayas and the impact on the geology, climate and people of the region; filmed in Bangladesh, Bhutan, China, India, Mongolia, Nepal and Pakistan.","image_url":"https://tmsimg.fancybits.co/assets/p15198428_b_h9_aa.jpg?w=360\u0026h=270","release_year":2018,"release_date":"2018-04-01","genres":["Special","Documentary"],"categories":["Show","Special"],"number_unwatched":0,"favorited":false,"last_watched_at":1780161788967,"last_recorded_at":1780043400463,"created_at":1780043400000,"updated_at":1783082102821},{"id":"27691411","name":"The Americas","summary":"Tom Hanks narrates a 10-episode television event from the executive producers of Planet Earth, exploring the extraordinary worlds and wildlife of North and South America. Scored by composer Hans Zimmer, the breathtaking journey follows amazing creatures living in their natural habitats across the supercontinent, including diverse terrains like the Atlantic Coast, Mexico, Wild West, Amazon, Frozen North, Gulf Coast, Andes, Caribbean, West Coast and Patagonia. Each location comes alive in never-before-seen footage showing the unique connectedness of the land that millions of people call home.","image_url":"https://tmsimg.fancybits.co/assets/p27691415_b_h9_ab.jpg?w=720\u0026h=540","release_year":2025,"release_date":"2025-02-23","genres":["Documentary","Nature","Animals"],"categories":["Show","Series"],"cast":["Tom Hanks"],"number_unwatched":0,"favorited":false,"last_watched_at":1784860713581,"last_recorded_at":1784854800067,"created_at":1740355200000,"updated_at":1784860766194},{"id":"24334154","name":"Mysteries of Life","image_url":"https://tmsimg.fancybits.co/assets/p24334154_b_h9_aa.jpg?w=360\u0026h=270","release_year":2023,"release_date":"2023-03-25","genres":["Special","Documentary"],"categories":["Show","Special"],"number_unwatched":0,"favorited":false,"last_watched_at":1780878040971,"last_recorded_at":1780767000494,"created_at":1780767000000,"updated_at":1783082102799},{"id":"30292529","name":"Surviving Earth","summary":"From the producers of Walking with Dinosaurs comes an eight-part docuseries spanning 450 million years that revisits eight of Earth's major extinction events. Bringing some of the planet's most extraordinary geological eras to vivid life, the all-new footage created in partnership with real scientific insight explores the lives of animals we know and love, including mammoths, saber-toothed cats and dinosaurs, alongside some of evolution's truly unique creatures, like gorgonopsians, pliosaurs, glyptotherium and more. Together, they tell the story of how life has endured the impossible -- and never stopped fighting for survival.","image_url":"https://tmsimg.fancybits.co/assets/p32655343_b_h9_aa.jpg?w=720\u0026h=540","release_year":2026,"release_date":"2026-01-01","genres":["Documentary","Nature","Animals","Ancient history"],"categories":["Show","Series"],"number_unwatched":0,"favorited":false,"last_watched_at":1784857737817,"last_recorded_at":1784851201613,"created_at":1781222400000,"updated_at":1784857791821},{"id":"Penn \u0026 Teller: Fool Us","name":"Penn \u0026 Teller: Fool Us","image_url":"https://image.tmdb.org/t/p/original/8fLyvZZ2yxDhjqc2z6L2iwtW4T3.jpg","number_unwatched":0,"favorited":false,"last_watched_at":1783114387026,"last_recorded_at":1781388485053,"created_at":1781305111000,"updated_at":1783114690624},{"id":"31474093","name":"Once Upon a Time in Space","summary":"Personal accounts from astronauts and scientists, covering key milestones of space exploration, global space rivalries and the future of humanity beyond Earth.","image_url":"https://tmsimg.fancybits.co/assets/p31474101_b_h9_ad.jpg?w=720\u0026h=540","release_year":2025,"release_date":"2025-10-27","genres":["Science","Documentary"],"categories":["Show","Series"],"cast":["Kristin Fisher","Jerry Linenger","Anna Fisher","Terry Virts","Mike Mullane"],"number_unwatched":0,"favorited":false,"last_watched_at":1784128681896,"last_recorded_at":1784077200532,"created_at":1784077200000,"updated_at":1784128775842},{"id":"Dark Space","name":"Dark Space","image_url":"https://s3.amazonaws.com/mtdb.galxy.prod/storage/media-images/posters/1nX1ew54mj3Ml0yeitcLfC8wXMitGhWphxtlxQhI.jpg","number_unwatched":0,"favorited":false,"last_watched_at":1784754231067,"last_recorded_at":1784566939859,"created_at":1784566939000,"updated_at":1784754426265}]
