Will the Channels DVR engine support multiple recording engines on the same local network? Example: I may want to install it on a NAS and a windows/Linux machine so when I select “record” on a program it will detect the two engines and let me select the destination.
If that is not possible, then the ability to have two engines on the network and have an option in Channels app to select which engine to use to record to.
Another question would be if the engine(s) can be selected by IP address.
