Quick question: is there a limit to the number of remote users that can access the remotedvr at the same time? (Aside from server hardware/bandwidth constaints/hdhr tuners)
No there is no way to do this built-in. The remote access feature is designed for personal use.
Hi,
So is there a limit or is there not a limit?
Oh I thought you were asking if there is a way to add a limit. Sorry for the confusion- I haven’t had my coffee yet.
There is no limit built in. You can stream as many streams as your hardware allows.
The only limit may be what your cable co allows if not OTA. Most agreements are for “personal use by household” including any of the recordings made meaning that you can do this for any users that live at that same address as the account owner. but then nobody really follows those limits… .
