This has been discussed in many threads where it has worked for some and not for others. I am one of the others. I purchased the shield hoping to use it to play Dolby Atmos since my Apple TV couldn't do it. I can get 5.1 to work just fine with my shield and home theater receiver but when I try to use the Atmos (trueHD) soundtrack, my receiver shows just a stereo source and then does the virtual surround sound on all speakers.
I haven't seen in any threads what the actual setting needs to be for this to work. I would really appreciate it if someone could give me the recipe on what the setting need to be for the Channels DVR and the shield. Also, did you get it to work with the Channel DVR stable release or do I need the beta version?
Thank you in advance!
