My step father passed away a few years ago and I've been helping my mom to do the upkeep on the family cabin in Western NC mountains that she spends about 6 months at. We've switched from DirecTV and DSL cable (about 6 megabits) to YTV with a cable 100 megabit connection (with 1 TB cap before extra charges kick in).
My mom likes to have 2-3 TVs on in the house during the day (she goes back and forth from room to room doing things) and usually will ABC on one TV, Madame Secretary (streamed via Netflix) on another and then something else on the 3rd TV. I've tried to tell her not to keep TVs on in rooms when she's not actively watching, but she's 72 and set in her ways, so it is what it is.
Now that Virtual Channels are a thing, I'm going to setup a channel that pulls Madame Secretary from a local HD vs. streaming as that will help with the bandwidth. I'm also going to try and get an antenna setup so that I can turn off ABC from YTV and just pull from the local OTA. It's a stretch though as signals in the mountains are a challenge and not always consistent and she's all about "I just want it to work".
I have a mix of wifi and wired devices (most TVs are through Wifi, I have a Snynology Mesh Wifi setup in the house). Currently I have a Raspberry PI I installed and played around with over thanksgiving, which has an external 5GB USB 3 drive attached. I included Pluto Docker, but thinking of removing as the only thing she found interesting was the 007 Channel which appears to be gone now. I also suspect it was eating up a lot of the total monthly bandwidth as we went over in November/December when we were only there for about 2 weeks.
All of the above to give you more insight into my question. I have an extra Nvidia Shield that I am considering installing. The Raspberry PI is headless and connected via wired Ethernet to the router (sitting right next to it). If I wanted to go the NVidia route, I would likely need to install either at a TV and run a wire, or same place as the Raspberry PI if it can be run headless (I don't know the answer to that). Running a wire to the TV isn't a huge deal.
I would say before the 9.0 fiasco, I was thinking Shield may be the better route to go, and have seen that it appears a fix has been uploaded, but for those of you that have played more with the hardware than I have, what's the recommendation on setting up something that my mom doesn't have to worry about (I only get there about 3 times a year to work on things, so need it to be very rock solid).
Thanks for any input and/or suggestions.
Jay
