So I watched a ton of live TV today and had it skip about 4 times. That being said the error message was different for 3 of them (So not sure if its different issue or you changed the logging). Twice it happened while watching and recording live TV same channel (But I hadn't really done that in the past and do that rarely so not sure that could be a slightly different issue). The last time it happened was probably hardware/system related based off the error message.
All that being said overall I think its in a pretty good state. I am actually super happy with how it is doing right now. If you didn't change the logging I think I am close to calling this fully fixed. I might have stumbled upon another tiny issue (maybe?) but I haven't seen that up till this point so whatever no big deal to me. And of course below is logs with comments above each.
Summary of each of the 4 issues in order.
Typical error message and it happened within 2-3 minutes of flipping on live TV which made me fairly nervous.
Different error was watching live at the same time as recording
Same as above (This and the above happened while watching a show for about 30-40 minutes)
Different error (In the error mentions doing too much work on the main thread... so this could be the shields fault and not Channels)
//Very shortly after turning ESPN on 11-13 11:09:59.180 9867 9867 V mpvstats: AV: 103.980 A-V: 0.000 Dropped: 0 Cache: 0.584s video + 0.000s audio 11-13 11:09:59.180 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=17.7Mb/sec 11-13 11:10:02.180 9867 9867 V mpvstats: AV: 106.983 A-V: 0.000 Dropped: 0 Cache: 0.484s video + 0.000s audio 11-13 11:10:02.180 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=17.7Mb/sec 11-13 11:10:02.436 9867 9907 V mpv : [ao/audiotrack] Underrun detected: 0 -> 1 11-13 11:10:02.444 9867 9907 W mpv : [cplayer] Audio device underrun detected. 11-13 11:10:02.444 9867 9907 V mpv : event: unpause 11-13 11:10:02.444 9867 9907 V mpv : [cplayer] Enter buffering (buffer went from 100% -> 0%) [0.000000s]. 11-13 11:10:02.444 9867 9907 V mpv : property: buffering = true 11-13 11:10:02.444 9867 9867 V PlayerActivity: state PLAYING -> BUFFERING 11-13 11:10:02.612 9867 9907 W mpv : [ao/audiotrack] getLatency: written=5981696 playhead=5983031 diff=4294965961 delay=76695.820732 11-13 11:10:02.665 9867 9907 V mpv : [cplayer] Still buffering (buffer went from 0% -> 25%) [0.128000s]. 11-13 11:10:02.673 9867 9907 V mpv : [cplayer] Still buffering (buffer went from 25% -> 6%) [0.032000s]. 11-13 11:10:02.675 9867 9907 V mpv : [cplayer] Still buffering (buffer went from 6% -> 0%) [0.000000s]. 11-13 11:10:02.681 9867 9867 V mpvstats: demuxer-cache-state: {cache-end=107.42399988888974, reader-pts=107.42399988888974, cache-duration=0.0, eof=false, underrun=true, idle=false, total-bytes=95926416, fw-bytes=739920, raw-input-rate=2325848, debug-low-level-seeks=0, debug-byte-level-seeks=1, debug-ts-last=9685.103500000001, ts-per-stream=[{type=video, duration=0.3837111111115519, reader=9684.71978888889, end=9685.103500000001}, {type=audio, duration=0.0, reader=9684.87688888889, end=9684.87688888889}], bof-cached=false, eof-cached=false, seekable-ranges=[{start=65.74207766666768, end=107.39199988888868}]} 11-13 11:10:02.715 9867 9907 V mpv : [cplayer] Still buffering (buffer went from 0% -> 57%) [0.288000s]. 11-13 11:10:02.862 9867 9907 V mpv : [cplayer] Still buffering (buffer went from 57% -> 76%) [0.384000s]. 11-13 11:10:03.062 9867 9907 V mpv : event: unpause 11-13 11:10:03.062 9867 9907 V mpv : [cplayer] End buffering (waited 0.617832 secs) [0.608000s]. 11-13 11:10:03.062 9867 9907 V mpv : [cplayer] restarting audio after underrun 11-13 11:10:03.063 9867 9907 V mpv : property: buffering = false 11-13 11:10:03.063 9867 9867 V PlayerActivity: state BUFFERING -> PLAYING 11-13 11:10:03.066 9867 9867 V mpvstats: demuxer-cache-state: {cache-end=108.12799988888946, reader-pts=107.51999988888929, cache-duration=0.6080000000001746, eof=false, underrun=false, idle=false, total-bytes=95909040, fw-bytes=2450928, raw-input-rate=2327025, debug-low-level-seeks=0, debug-byte-level-seeks=1, debug-ts-last=9684.736466777778, ts-per-stream=[{type=video, duration=1.0844111111109669, reader=9684.753155555556, end=9685.837566666667}, {type=audio, duration=0.6080000000001746, reader=9684.97288888889, end=9685.58088888889}], bof-cached=false, eof-cached=false, seekable-ranges=[{start=66.49283322222254, end=108.0959998888884}]} 11-13 11:10:03.066 9867 12568 W AudioTrack: releaseBuffer() track 0x2f21c65800 disabled due to previous underrun, restarting 11-13 11:10:03.346 9867 9867 V mpvstats: AV: 107.534 A-V: 0.000 Dropped: 9 Cache: 1.001s video + 0.480s audio 11-13 11:10:05.196 9867 9867 V mpvstats: AV: 109.402 A-V: 0.000 Dropped: 9 Cache: 1.151s video + 0.448s audio 11-13 11:10:05.196 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=17.7Mb/sec //Different error but saw it again shortly after going to ESPN News (I was watching live and recording this one at same time) 11-13 14:28:49.684 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=12.5Mb/sec 11-13 14:28:52.684 9867 9867 V mpvstats: AV: 58.125 A-V: 0.000 Dropped: 4 Cache: 1.618s video + 0.640s audio 11-13 14:28:52.684 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=12.5Mb/sec 11-13 14:28:54.759 9867 17031 W AudioTrack: releaseBuffer() track 0x2f21c65800 disabled due to previous underrun, restarting 11-13 14:28:54.760 9867 9907 V mpv : [ao/audiotrack] Underrun detected: 0 -> 1 11-13 14:28:54.870 9867 9877 I s.dvr.app.alph: Background concurrent copying GC freed 316099(11MB) AllocSpace objects, 37(2MB) LOS objects, 49% free, 11MB/23MB, paused 88us total 266.066ms 11-13 14:28:54.872 9867 9875 W System : A resource failed to call end. 11-13 14:28:54.872 9867 9875 W System : A resource failed to call end. 11-13 14:28:55.519 9867 9867 V mpvstats: AV: 60.928 A-V: 0.000 Dropped: 10 Cache: 1.668s video + 0.704s audio 11-13 14:28:55.685 9867 9867 V mpvstats: AV: 61.095 A-V: 0.000 Dropped: 10 Cache: 1.735s video + 0.704s audio 11-13 14:28:55.685 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=12.1Mb/sec 11-13 14:28:58.009 9867 17056 V ApiServer: REQUEST: GET /log 11-13 14:28:58.685 9867 9867 V mpvstats: AV: 64.098 A-V: 0.000 Dropped: 10 Cache: 1.501s video + 0.640s audio 11-13 14:28:58.685 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=11.5Mb/sec //Again with the different error on ESPN News again (recording still) 11-13 14:59:36.258 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=15.1Mb/sec 11-13 14:59:38.466 9867 9867 V mpvstats: AV: 1903.418 A-V: 0.000 Dropped: 17 Cache: 2.102s video + 1.120s audio 11-13 14:59:38.477 9867 9907 V mpv : [ao/audiotrack] Underrun detected: 1 -> 2 11-13 14:59:38.478 9867 9907 W mpv : [ao/audiotrack] getLatency: written=106568000 playhead=106577668 diff=4294957628 delay=76695.671929 11-13 14:59:38.490 9867 17031 W AudioTrack: releaseBuffer() track 0x2f21c65800 disabled due to previous underrun, restarting 11-13 14:59:38.556 9867 9877 I s.dvr.app.alph: Background concurrent copying GC freed 304279(11MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 11MB/23MB, paused 90us total 543.147ms 11-13 14:59:39.259 9867 9867 V mpvstats: AV: 1904.369 A-V: 0.000 Dropped: 35 Cache: 2.069s video + 1.024s audio 11-13 14:59:39.259 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=12.4Mb/sec 11-13 14:59:39.466 9867 9867 V mpvstats: AV: 1904.570 A-V: 0.000 Dropped: 35 Cache: 2.052s video + 1.024s audio //ACC Network (Based of the error message it sounds like the shield not the software but including it just in-case!) 11-13 18:53:59.352 9867 9867 V mpvstats: AV: 12366.930 A-V: 0.000 Dropped: 13 Cache: 4.204s video + 3.200s audio 11-13 18:53:59.353 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=14.2Mb/sec 11-13 18:54:00.702 9867 9867 I Choreographer: Skipped 37 frames! The application may be doing too much work on its main thread. 11-13 18:54:00.711 9867 9867 V mpvstats: AV: 12367.664 A-V: 0.160 Dropped: 19 Cache: 4.788s video + 3.840s audio 11-13 18:54:00.789 9867 18335 W AudioTrack: releaseBuffer() track 0x2ed2d00000 disabled due to previous underrun, restarting 11-13 18:54:00.802 9867 9907 V mpv : [ao/audiotrack] Underrun detected: 0 -> 1 11-13 18:54:00.882 9867 9877 I s.dvr.app.alph: Background concurrent copying GC freed 285439(10MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 10MB/21MB, paused 80us total 822.787ms 11-13 18:54:01.713 9867 9867 V mpvstats: AV: 12368.932 A-V: 0.000 Dropped: 28 Cache: 4.454s video + 3.776s audio 11-13 18:54:02.354 9867 9867 V mpvstats: AV: 12369.583 A-V: 0.000 Dropped: 28 Cache: 4.605s video + 3.872s audio 11-13 18:54:02.354 9867 9867 V streamstats: strength=100% quality=100% symbol=100% rate=13.6Mb/sec
I have said it before but thank you so much! I am sure its not a easy issue to work on/track down at all and I do appreciate it. Curious to hear if you have any comments on the above. And of course, If there is anything else I can test or look into let me know!
