NWSL+ channels m3u?
Has anyone created a m3u for NWSL+ games?
Watching NWSL games is a challenge because they are streamed across so many different platforms. Some games are on ion (Pluto TV), some on ESPN+, some on Amazon Prime, and some on NWSL+. I can't figure out how to record the ones streamed on NWSL+.
According to what i can see here,
The devision i think is part of Gothem Sports network.
The service is supported on the ESPNpllus docker with a valid subscription.
This option would allow recording of the event.
I think Gotham Sports (MSG) only carries the New York team (coincidentally named “Gotham FC”) and only for select matches.
I can take a look at adding this to EPlusTV.
That would be awesome since I already have that installed and working.
Content can be found here (free account required): https://plus.nwslsoccer.com/home
Content available varies by geo. For US, it is only games that are not streamed on any other platform. For outside US, most games are available for live streaming.
Replays are generally made available 3 days after airing, with the same geo restrictions.
Thanks,
-Mike
Did you ever get this working? I don't have Channels but was looking for a solution specifically for soccer and the NWSL. If Channels would work as a DVR for NWSL games, then I would probably get it.
It looks there was a post in Nov 2024 saying that NWSL+ had been added but not sure if it works.
The linear channel that shows re-runs of old games works, but the on demand games seem to use DRM and don't work.
