NZ channels
@matthuisman
Hi Matt,
I am trying to implement your m3u for NZ channels. Of the sections listed, which is most suitable for me to use within Channels.
I tried the Raw version. Of the channels I tried TV NZ1 and NZ2 report a server/incorrect format. The 3 you listed requiring local IP are working for me using a smartdns.
The EPG isn't coming up with all of them. I will look at a bit more.
Thanks
RAW is what you should be using
Thanks Matt.
For some reason I still get the same error. The screenshot is below.
Log:
2022/08/03 20:18:21.820185 [ERR] Failed to start stream for ch10417: M3U: Could not fetch playlist: i.mjh.nz: get https://i.mjh.nz/nz/tv.10.m3u8: 403 Forbidden
2022/08/03 20:18:21.871534 [HLS] Couldn't generate stream playlist for ch10417-dANY-ip127.0.0.1: M3U: Could not fetch playlist: i.mjh.nz: get https://i.mjh.nz/nz/tv.10.m3u8: 403 Forbidden
2022/08/03 20:18:21.871634 [HLS] Stopping transcoder session ch10417-dANY-ip127.0.0.1
2022/08/03 20:18:23.715270 [HLS] Stopping transcoder session ch10417-dANY-ip127.0.0.1
I extracted the stream myself from the TV NZ website. I got this (below). When I add this as custom channels into Channels it seems to work
https://d2ce82tpc3p734.cloudfront.net/v1/manifest/b1f4432f8f95be9e629d97baabfed15b8cacd1f8/TVNZ_1/4c2dbdee-ba90-4f4d-bc3d-2eda0560cd5e/0.m3u8
all that i.mjh.nz url does is redirect to: https://duoak7vltfob0.cloudfront.net/v1/master/b1f4432f8f95be9e629d97baabfed15b8cacd1f8/TVNZ_2/master.m3u8
Does https://duoak7vltfob0.cloudfront.net/v1/master/b1f4432f8f95be9e629d97baabfed15b8cacd1f8/TVNZ_2/master.m3u8 workin channels?
@matthuisman
Hi Matt,
I am also trying to use your raw playlist and getting the same error reported above - only for TVNZ channels it seems.
When I try and add the cloudfront link above I get the following error.
invalid source url: unexpected URL without #EXTINF header
I am based in NZ and the raw playlist works fine for me with PVR Live on Android TV.
Any suggestions to help with this?
Thanks
Henry
Hi, New to Channels DVR
I ran into the problem of TVNZ1, 2, DUKE and JUICE showing a 403 forbidden error on Matts playlist.
Eventually got them all working with a combination of the playlist URL and the following text entries.
#EXTM3U x-tvg-url="https://iptv-org.github.io/epg/guides/en/i.mjh.nz.xml"
#EXTINF:-1 tvg-id="TVNZ1.nz" tvg-logo="https://i.imgur.com/Nx76HUE.png" group-title="General",TVNZ 1
https://d2ce82tpc3p734.cloudfront.net/v1/master/b1f4432f8f95be9e629d97baabfed15b8cacd1f8/TVNZ_1/master.m3u8
#EXTINF:-1 tvg-id="TVNZ2.nz" tvg-logo="https://i.imgur.com/9sV4dbH.png" group-title="General",TVNZ 2
#EXTINF:-1 tvg-id="JuiceTV.nz" tvg-logo="https://i.imgur.com/WaaaW0w.png" group-title="",Juice TV
https://juicex.nz/hls/mystream.m3u8
#EXTINF:-1 tvg-id="mjh-tvnz-duke" tvg-name="DUKE" tvg-logo="https://i.mjh.nz/.images/tvnz-duke.png" group-title="Nz",DUKE
https://dayqb844napyo.cloudfront.net/v1/master/b1f4432f8f95be9e629d97baabfed15b8cacd1f8/TVNZ_Duke/master.m3u8
Didn't really know what I was doing, just guess work and copy and pasting. Anyway all the channels in the playlist now work and show EPG. I have 4 orphaned duplicate channels which work but don't display the EPG. A bit messy but not an issue as I don't have them in favourites.
Wish I'd seen this topic first, Kors solution above would have been much easier.
