Olivetin EZ-Start Next Generation on Synology
I am attempting to to install Olivetin EZ-Start following the directions in Next Generation. I successfully installed Portainer (although I had to add an additional env to force API version 1.43(?) . When I run " OliveTin Environment Variables Generator/Tester", I get the following result.
TAG=latest
DOMAIN=
HOST_PORT=1337
CHANNELS_DVR_HOST=172.17.5.5
CHANNELS_DVR_PORT=8089
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Mountain
HOST_DIR=/data
DVR_SHARE=/channels-dvr/recordings
LOGS_SHARE=/channels-dvr
TUBEARCHIVIST_SHARE=/channels-dvr/recordings
DVR2_SHARE=
LOGS2_SHARE=
TUBEARCHIVIST2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
TUBEARCHIVIST3_SHARE=
HOST_SFS_PORT=8080
FOLDER=/web
cat: /config/olivetin.token: No such file or directory
PORTAINER_TOKEN=
PORTAINER_HOST=172.17.5.5
PORTAINER_PORT=9443
PORTAINER_ENV=13370
PERSISTENT_LOGS=false
As I have searched and worked on this for 3-4 days, I'd appreciate any assistance for this nubie Docker user.
2 posts were merged into an existing topic: OliveTin EZ-Start: The Next Generation. Deploy OliveTin-for-Channels from the Command Line without the Need for Portainer to be Installed in Advance!
