I would have to test it. I just output all my channels from OliveTin, pulled out the ones I wanted and put those into their own custom channel (so copy and paste), and deleted the last line, which was the m3u8 link, if I recall. I then uploaded the logos to my web server, and pasted the link to the logo after “ tvg-logo” for each channel.
Sounds like a great approach to me!
@Fofer @cyberskier I've added this Custom Channel Logos "trick" to the latest build of OliveTin, bnhf/olivetin:latest and bnhf/olivetin:2024.02.21.
The process is as described a couple of posts back, with much more detail and screenshots to be found here:
New OliveTin-for-Channels pushed today with tags :latest and :2024.02.23. Total update for all sample docker-composes for every extension somebody might want to use with Channels (that I could think of). All examples are for use with Portainer-Stacks! I also posted them all here:
So dumb/newbie question: How do I get the client names to input as variables for the “send message” feature? My guess would be from the client section of the DVR, but I have some client names with spaces in them.
(I believe I’ve otherwise figured out how to add the CHANNELS_CLIENTS variable, but just don’t know where to find the client names)
The way I set this up, any message is sent to ALL defined clients. My thinking was, if the message is intended for just one person, put their name(s) in the title. Overall, I've been trying to keep the data required for individual actions as streamlined as possible.
Thanks. But don’t I first have to define those clients in Portainer in an environment variable? Or can I just not do that, and it goes to all clients by default?
For sure. It's a space separated list of either hostnames or IP addresses:
- CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP
OK, thanks. I'm on an eero network, so I can find the hostnames in the eero app, I believe.
I finally installed OliveTin for Channels and I can see the interface.
However, it doesn't see my DVR.
Everything is running on a single computer with Windows 11.
This is my customized Portainer-Stack (I removed things that I didn't think were relevant to my configuration):
version: '3.9'
services:
olivetin:
image: bnhf/olivetin:${TAG} # Add the tag like latest or test to the environment variables below
container_name: olivetin
ports:
- 1337:1337
environment:
- CHANNELS_DVR=${CHANNELS_DVR} # Add your Channels DVR server in the form hostname:port or ip:port
- UPDATE_YAMLS=${UPDATE_YAMLS} # Set this to true to update config.yaml
- UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set this to true to update all included scripts
volumes:
- ${HOST_DIR}/olivetin:/config # Add the parent directory on your Docker you'd like to use
restart: unless-stopped
static-file-server:
image: halverneus/static-file-server:latest
container_name: static-file-server
ports:
- 8080:8080
environment:
- FOLDER=${FOLDER}
volumes:
- ${HOST_DIR}/olivetin/data:${FOLDER}
#volumes: # use this section if you've setup a docker volume named channels-dvr, with CIFS or NFS, to bind to /mnt/dvr inside the container. Set ${HOST_DIR} to channels-dvr (HOST_DIR=channels_dvr) in that example
#channels-dvr:
#external: true
Environment variables:
TAG=latest
CHANNELS_DVR=127.0.0.1:8089
CHANNELS_CLIENTS=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Eastern
HOST_DIR=D:\
FOLDER=/web
Obviously, I messed up somewhere.
Result of the Ping action:
Sat Feb 24 12:16:27 EST 2024
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (7) Failed to connect to 127.0.0.1 port 8089: Connection refused
HTTP Status: 000
Effective URL: http://127.0.0.1:8089/
One time run mode used...
foreground.sh is exiting for pingcdvr with exit code 0
Try exec'ing into the container (use the "Quick Action" button for that purpose in Portainer-Containers), and see if you can ping 127.0.0.1 and localhost. Also, try the hostname and IP of this PC -- that should give us a baseline of what's working.
EDIT: I don't have Channels installed on my Windows 11 PC, but I do have OliveTin there for testing, and I was able to reach the PC on all 4 addresses.
EDIT2: OK, so I tried the curl command I use with another open port on my Windows 11 PC. 127.0.0.1 and localhost both failed, but nuc12-pc and 192.168.110.237 both succeeded. Not sure why this is the case, but there are some idiosyncrasies with the whole Docker/WSL/Windows thing. So, I'd suggest trying either your system's LAN hostname or IP address to see if you have better results.
Is there a post/location where I can get/install Olive Tin For Channels, with installation instructions?
First post in this thread should do the trick. Let me know if you have any questions.
I'm a docker novice but I installed docker a while back for play but didn't do/try/learn much. I've been instead surviving by writing bash scripts using cygwin on Windows to wget/manipulate stuff from my CDVR server, but that's about it. I see the advantages of the OliveTin For channels setup and want to get involved.
My CDVR server runs on a dedicated i7 Windows laptop separate from my main PC. My first decision point will be should I install docker/OTFC on the PC hosting my server, or, on my main PC? Maybe with the correct environment variables it won't matter. I suppose the docker-compose is like an installation script that pulls from a repository somewhere?
It shouldn't matter where you install it, but containers can be a bit like potato chips -- it's hard to limit yourself to one.
In other words, make sure that whatever system you choose is available 24/7 as you're very likely to have multiple containers running to which Channels needs full-time access.
Docker is a Linux thing at heart, but can be run on Windows systems using the Windows Subsystem for Linux (WSL2) as a backend. Most people go with Docker Desktop as a starting point -- for that Windows look-and-feel. You'll also need to install Portainer, which can be done from the command line of whatever WSL2 distro you choose -- or it can be installed as an extension to Docker Desktop, from its GUI.
Docker-compose is essentially a more elegant way to deploy containers using the YAML scripting language. And yes, the containers themselves are download from one of several "container hubs", based on the "image" statement in each docker-compose.
Thanks for the suggestions. I will try later in the evening.
I am able to connect locally but not from another machine do I have to change the network to bridge or host ?
Unless it's specifically needed for some reason, using host networking with Docker is not recommended (for best container isolation and security). And, unless otherwise specified, bridge networking is the default. What OS is your Docker host running? Could this be a firewall issue?
Windows Desktop ... thanks bridge worked ... everything looks good.
This is great @bnhf thanks for your hep using docker compose.
