same url see below:
Go ahead and try setting that up as a single channel in ADBTuner, and see if it'll actually play the channel through a couple of time slots. You can use the preview mode in ADBTuner for testing.
How did you grab the JSON -- via a curl command?
That is because I run a vpn and the web player does not like it. I assure you world news tonight is on on abc. I plugged the url into adbtuner and played the output in vlc see below:
except it is the same url as from earlier when the news at 6 was on. Different show same channel
Leave it playing for the next hour or two, just to be sure. Let me know how you grabbed the JSON, and I'll put something together in OliveTin -- once you've confirmed playback through multiple shows.
see the image in the below filebin. it will show you everything:
world news tonight ends at 7:00 I will leave it up
The longer the better. I'm sure neither of us wants to spend time on a wild goose chase. I'd like to see the link remain valid through at least 3 different programs.
It's been a while for me with YTTV, but as I recall they have multiple deeplinks for the same channel -- even within a given broadcast area. I remember comparing what I put together by hand, to what others were posting, and there weren't that many matches.
@techpro2004 What's the verdict on whether those links are for stations or programs? Are you still able to tune today with links from yesterday?
So for some odd reason the app was showing nbc not abc. What is the correct format for the deep links these days? However the link still works in firefox and chrome. It shows eyewitness news at noon. the only issue is I am not sure if it is for the correct region as I am using a vpn so it says video unavailable.
That could happen with an invalid link, the app would just show the last station tuned.
You had it right for YTTV: https://tv.youtube.com/watch/$CHANNEL
To be sure you have the correct links, we need to see the correct channel actually streaming, which you should be able to do with a single test channel in ADBTuner.
Yeah...when it comes to YTTV, I find that the links rarely change. I used the json creator in Olivetin to import my channels into adbtuner and it all worked. Some channels would have to be added like the local channels and the NBCSN feeds but thats about it
Make sure @techpro2004 that you have the right link for each local channel.
What we're attempting to do is to create a complete subscribed lineup importer, like we have for DTV. It may or may not be successful, but we're taking a shot. :slight_smile:
I think that sounds even better. Of course, you would have to know EVERY local station and every link to it and gracenote id. YTTV is a bit more locked down than DTV when it comes to snooping around their api.
Good luck :smiley:
disregard that. it is the show id. I was using the id posted by mackid before, In order to get this working we are going to have to setup a cronjob of some type to grab the id.
or we can use the videoId at the end of the section that plays what is on now. see below
edit: Just realized @anon38303228 posted this last night.
The channel IDs are there somewhere. Users have been grabbing them individually from a browser since the start. The question is can we figure out how to grab them in bulk? Otherwise the manual method is the only option. Back when I had YTTV, I used drag-and-drop to add them to Google Sheets, outputted that as a CSV file and imported from there. Not super elegant, but it worked.
Candidly, the FastChannels ah4c bridge with DTV, is the absolute king in this category right now. If you're looking for fast, reliable tuning and setup that doesn't require much of what we're talking about here, show YTTV the door and restart your DTV sub.
see my post just before your last one.
Are you saying this is the correct ID for the channel? If so, can you do the tests we talked about yesterday?
yes it is the correct id. there is something wrong with adbtuner it wont tune, but apituner tunes correctly. I am leaving it playing for now, fyi, I just checked and the id is still the same.
