fwiw - i just tested a F1 event from ADB on a firestick and it went right to the Apple TV app on firestick. i blame ADBTuner :slight_smile:
To be fair, it could also be a misconfiguration on my end, but everything works with Peacock with the same setup for example.
How did you test an F1 event? Part of the debugging challenge for me is they happen pretty irregularly and I won't be awake when the race starts tomorrow at 4am for example.
I forced the ADB command (that FDL would send) to my FireStick. It opened AppleTV and went to the event page.
so, i'd have to Assume it'll work tomorrow
I tested too, using a slightly different method, and it took me to the splash page for the event.
If you look in the FDL Event Inspector, you can grab a link for an upcoming event:
So I grabbed this link:
https://tv.apple.com/us/sporting-event/azerbaijan-race/umc.cse.454f6ug3pg2vxpx8zjlxn5uis
And plugged it in here, in place of the current "URL or Identifier" (make sure to copy and save the existing one to replace it after the test):
Save it, and then click "Preview". If every thing is setup right you should see something like this:
If that doesn't work, check the obvious stuff first, like making sure you have the Apple TV app loaded on your sticks, and that you're signed in. Also, make sure your apple_f1 channels look like my screenshot.
Ah, that's super helpful and that does also work for me. However, looking at the ADBTuner logs from qualifying this morning I do now see this:
Resolving dynamic URL (http://fruitdeeplinks.chrispederick.internal:6655/api/adb/lanes/apple_f1/4/deeplink?format=json) for channel.
Retrieved dynamic URL data: {'deeplink': None, 'lane_number': 4, 'message': 'No event scheduled at this time', 'provider_code': 'apple_f1', 'status': 'success', 'title': None}
Does this mean that FDL was not returning a deep link (seemingly since it thought that there was no event scheduled)? The only thing I'm wondering if that's the case is that I default to having all my passes in Channels start 1 minute early to account for tuning time - could this be why FDL didn't return a deep link in this case?
So there was an event in the guide in that lane at a time 1 minute from when you wanted to start recording? If so, that's interesting and may be a question for @KineticMan -- but generally with these event-based links you're probably best off not adding any padding to the front of the recording.
Yeah, this totally makes sense that this would cause problems now that I think about it. I haven't seen this before with Peacock and Paramount+ which I also used to start 1 minute early, but I've removed all the padding for these passes and we'll see if things work as expected tomorrow :crossed_fingers:
Okay, so removing the padding fixed the tuning issue...however, it got stuck on this screen and didn't actually start playing the event:
Is that something that can be fixed in ADBTuner? (Happy to take this to a different thread if this is now more ADBTuner specific, but you know I'd still just bug you over there @bhnf :smile:)
You are using the "Apple TV" configuration like in my screenshot above correct? Because looking at that config "Watch" should have been selected for you:
  "name": "FruitDeepLinks - AppleTV v1.0 (FireTV and AndroidTV)",
  "author": "bnhf",
  "version": "1.0",
  "description": "AppleTV for FruitDeepLinks. Compatible with FireTV and AndroidTV devices.",
  "uuid": "8cf23241-09e3-4b79-90fe-576086707462",
  "global_options": {
    "wait_for_video_playback_detection": false,
    "use_fixed_delay": true,
    "fixed_delay_seconds": 5,
  "pre_tune_commands": [
    "input keyevent KEYCODE_MEDIA_STOP"
  "tune_commands": [
    "am start -W -a android.intent.action.VIEW -d '||TARGET_URL_OR_IDENTIFIER||' '||TARGET_PACKAGE_NAME||'"
  "tune_match_text_commands": [
      "match_text": [
        "watch",
        "live",
        "mls",
        "mlb",
        "don't allow"
      "commands": [
        "input keyevent KEYCODE_DPAD_CENTER"
      "start_checking_after_seconds": 5
  "post_tune_commands": [
    "input keyevent KEYCODE_HOME"
Yup:
Using channel configuration: FruitDeepLinks - AppleTV v1.0 (FireTV and AndroidTV) (bnhf) (8cf23241-09e3-4b79-90fe-576086707462)
Further down in the ADBTuner logs:
Starting tune match text monitoring. Match commands: [{'match_text': ['watch', 'live', 'mls', 'mlb', "don't allow"], 'commands': [{'type': 'ADB', 'command': 'input keyevent KEYCODE_DPAD_CENTER'}], 'start_checking_after_seconds': 5}]
Tuning completed after 12.4 seconds. Display was None, application (com.apple.atve.amazon.appletv) was running.
On screen text: '“tv formula 1 - baku city circuit baku  =d -  a et ee  ee af ey ee ete wt soy'
Text match result: Text to match: ['watch', 'live', 'mls', 'mlb', "don't allow"]. Matches found: None.
On screen text: '“tv formula 1 - baku city circuit baku  c= -  sn er a sw (aes ee'
On screen text: 'sa ae == a ae we os awe ='
And that just continues to repeat.
This might be something to bring up with @turtletank then in the ADBTuner thread. It should be matching either "Live" or "Watch" and then sending a DPAD_CENTER. Maybe there are some tweaks that could be made to Tesseract OCR to more accurately read the text in those buttons.
Your list of channels is old and out of date for youtube tv for adbtuner. Please update it. I really like the way you did dtvstream, Unfortunately I am no longer with them as they raised my bill.
What Action are you using where you're seeing an existing list of YouTubeTV channels?
Unfortunately, YTTV does not have an API like DTV does where we can grab your subscribed channel list (at least that we've found). And even then, it'd be unlikely to include the Gracenote Station ID, which is a very nice perk of the DTV lists we've been able to capture.
I am using the create a youtube tv m3u or json action all the way at the end of the list
A link extractor addon for firefox picked up on the urls so there must be a way to use that
That Action requires you to supply a CSV, M3U or JSON file as a starting point, and then it'll create an output file in one of several formats. It'd be great to be able to pull one's YTTV channel list from the guide or wherever, so if you can figure out the basics, I can automate it fully. From there, we can either populate those channels into ADBTuner via its API, or create an ah4c M3U.
this is what I have. If you need anything else let me know:
bingo! see below
except the url to watch a channel is https://tv.youtube.com/watch/"videoId"
and the videoids are in the file I just uploaded.
without the Quotes
news at 6 is over att 6:30. Will test then.
