How long does it take to populate content on an Onn Pro? My phone browser did it right away.
To speed up my ONN I set it to Apps only mode ... Got rid of all that stuff trying to load in the home screen.... nice clean interface ....
On Later is instant, it doesn't need to populate.
If you are seeing a blank screen, you might be hitting a bug on Android. You'll need to visit your Channels DVR Server web admin and go to On Later there. From there, use the Fine Tune button to add at least one preferred channel, genre, or sport.
So I’ve done this and on the web admin and android shield tv, and my iPhone none of them populate anything in that section, same thing with sports section, and news… I’m at a loss
Just exclude 1 Channel you do not watch under finetune on later .... that way it checks all availible channels.
In my case I simply excluded one of my Cameras 1.1 but can be done with any Channel..
That’s the setup I want with the sports more than anything and can’t get anything
Is there anyone I can reach out to for this? I’ve been on it for hours it’s def glitched
What are your sources? It could be something wrong with the guide data you’re using?
On Later isn’t guaranteed to work with Third Party sources and guide data via Custom Channels.
Submit diagnostics so we can take a look at why this might be.
Logs have been submitted as 48dcd391-5aae-4087-be40-e165ba42ca1e
If I have to change the editor to get it I will. What does everyone else use?
Do you even have any guide data applied to your channels?
If you go to the guide or On Now, do you see anything?
Are you using an IPTV service?
Yes I am. I’ve had it work before but maybe I used a different editor can’t remember
If it's one of those Pirate sites, Channels doesn't play well with it an they won't support it.
Then what do you do to get it? If you don’t use IPTV?
Also I don’t use any pirate sites it’s strictly IPTV live tv
Ok. I was going buy your user name, which is a Pirate site.
